Lift brackets for a sidekick.
  • 3718 Views
Offline Mythose
  • 361
« on: June 07, 2005, 03:30:40 AM »
Could anyone send me the mesurments for a drop bracket for the front and rear diff?
I have a friend that has a full blown machien shop, CNC machiens and all, and he ows me for some networking that i am doing, and he could make all the parts for a sus lift for my track, i just need to know the angles that i need the front and rear diff at.
Re: Lift brackets for a sidekick.
« Reply #1 on: June 07, 2005, 11:48:46 AM »
Sent you a Pm
Offline weaver
  • 145
  • all i want to do is make my suzuki happy
« Reply #2 on: June 07, 2005, 01:09:54 PM »
what about having this fellow make some wheel spacers and having these sent to me.... ;D
for money if you insist. ;)
98 2door clothtop stocker
2" BodyLift, 15x7's, 235's,
soon- filter, exhaust, etc. etc. etc. coil spacers, etc. etc. & more-----i think
Offline Mythose
  • 361
« Reply #3 on: June 09, 2005, 04:05:07 AM »
How much of a spacer you looking for?
« Reply #4 on: June 09, 2005, 02:35:10 PM »
These are made elsewhere.
By the way, here are some pics of the brackets and the list name:
AXLE DROP LINK CENTER
AXLE DROP LINK RIGHT
AXLE DROP LINK LEFT
It's designed to work on a 3" kit for a Sidekick. I hope it works! ;D
www.4xfourart.com
« Last Edit: June 09, 2005, 02:35:59 PM by trickker »
Offline Guardrail
  • 101
« Reply #5 on: June 09, 2005, 05:55:06 PM »
Will those work on a GV?  If so, where can I get some?  I have an idea to get drop brackets for the axles, spacer blocks for the front crossmember with the rack and pinion and a drop bracket for the rear A arm mounts similar to those that used to be in the Explorer Pro Comp kit.  How does this sound to you guys?  Anybody interested in building it for me?  I am not an engineer or a welder.
Can he say that here
Later,
Guardrail
Offline Mythose
  • 361
« Reply #6 on: June 10, 2005, 02:38:10 AM »
Thanks Rod i will get back to you next week or so, kind  of a  full weekend this week gota go pick up a boat, "only 4x longer then the zuk" humm what would it take for a zuk to pull a 28' cabin cruser?", nah thats what the sub is for just means i gota get new gears for it. 4:11 aint squat with 38.5 tires, event with close to 300hp" on saturday.
a trip up to pick up a motor in salem.  on sunday.
work on monday, and put the motor in "the zuk" during the week/ wash the boat- tear apart the intake on the boat and rebuild the carbs-stablize the fuel / maby a litle crossmember work, a little glass, some blue marien paint, gota get it ready B-Fore the 4th!
oh and I gota find a set of 5:66 or 5:83 gears for the sub,  atleast a R&P for the rear end or it aint gona pull that thing out on the watter on the 5th LOL.
that is this week. ohh yeah and work 6:00 to 3:30 mon - fri
« Reply #7 on: June 10, 2005, 04:44:25 PM »
Heres what I know.
No
Why you ask?
Cause the GV is wider that a Kick
The top brackets are off a stock Kick and the bottom ones are off a 99-01 GV
Facing the front and look towards the rear of Rig
Left one mounts to the diff side and the right one mounts to the right side of the axle
(Dang it! Uploader not working, had to use my Cardomain site :-/)
How do I know?
Well I had to buy the whole front axle off of a GV to get the steel diff so I installed the steel axle too ;D
Offline Guardrail
  • 101
« Reply #8 on: June 10, 2005, 06:52:27 PM »
Ah well,  It was a nice thought anyway.  Thanks for the info.
Later,
Guardrail
