u- joint replacement
  • 2006 Views
Offline kamaca
  • 9
« on: November 13, 2008, 04:46:15 PM »
hey all,
i just removed and replaced the rear u- joint on my 1988 samurai. when reinstalling the c-clips i am only able to get one clip in on one cap but can't get the opposite clip in. new clips are slightly thicker . what's the fix ? thinner clips ??
thanks , pete
Offline pepatt
  • 174
Re: u- joint replacement
« Reply #1 on: November 13, 2008, 08:00:21 PM »
If you got the clip in on one side I'll conclude that the clips fit in the detents.
I'd say you don't have the bearing caps seated properly.
Are you using a press or another method?
pepatt
« Reply #2 on: November 13, 2008, 10:29:10 PM »
I just reuse the old clips, make sure you put the sharp side out on them, and no usa u joints with the grease fitting on them on the rear shaft. call t.t. he sells a nice jap u-joint for 20.00 from mitsubishi uj-625 (old number ) but there good ones for the money.
Offline kamaca
  • 9
« Reply #3 on: November 14, 2008, 05:20:12 PM »
thanks for the response. why no usa u joints with grease fittings??
Offline ROSS
  • 1412
« Reply #4 on: November 14, 2008, 05:43:52 PM »
most are crap and don't last
Offline kamaca
  • 9
« Reply #5 on: November 15, 2008, 06:56:54 AM »
thanks for the input. i picked up thinner retaining clips and snap ring pliers ( beats the heck out removing them with an awl and screw driver ) rings popped right in like they should !
thanks
pete
