Fender trimming
  • 10 Replies
  • 3521 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
Fender trimming
« on: November 15, 2008, 11:48:24 AM »
ok so i got jeffs coil spacers and i got 2 in wheel spacers on 2357515 bfg atto's when i turn they are rubbing what is the easyest way to trim the fenders.  i never have done any body work.  so someone please help me.
Offline jeff1997
  • 1228
  • 27
Re: Fender trimming
« Reply #1 on: November 15, 2008, 12:05:04 PM »
Put making tape on the area to be trimmed. Layout the lines you want to cut, use a die grinder or 4.5" electric with a thin cutoff wheel and go to town. That is the neat way to do it. If you don't mind possibly scarring up the surronding metal, you can use the trusty sawzall. Lay it out with the tape on first.
3" Masterkit1 body lift
Custom strut spacers
Offline skitime
  • 302
Re: Fender trimming
« Reply #2 on: November 15, 2008, 01:55:33 PM »
Let me guess, you put those tires on stock rims right?  If so you are probably rubbing on the frame at the rear of the tire.  Cutting fenders is not going to fix that.  You need to space the wheels out or get wheels with the correct backspacing.  I had 8 inch rims with 3.75 backspacing and then the tires did not rub.
Offline rascott
  • 669
  • 15
Re: Fender trimming
« Reply #3 on: November 15, 2008, 04:34:21 PM »
i was able to form my front wells mostly by bending the sheet metal in with channel locks, and re-installed the plastic well treatment. hammered the inside a little. only a little cutting to make it happen.
almost looks stock. mabe.
you have spacers- mabe rubbing in front also? i'd think bending would work there too.
i have 7" rims and 31x10.5's(3 1/2" back space?)
i have a little rub on frame from flex/turn, but don't care.
Re: Fender trimming
« Reply #4 on: November 15, 2008, 04:43:06 PM »
Another trick for bending them is to use a small socket behind the wheel well, then using the pliers to roll the body around the socket.  That way you get a smooth bend.
Offline kubik1981
  • 232
Re: Fender trimming
« Reply #5 on: November 15, 2008, 05:26:03 PM »
thank you all for your input i will see what i can do.  Also no i do not have stock rims i have 15x8's with 2in wheel spacers
Offline skitime
  • 302
Re: Fender trimming
« Reply #6 on: November 15, 2008, 07:19:39 PM »
Where is it rubbing then?
Offline SNJSamurai
  • 386
Re: Fender trimming
« Reply #7 on: November 15, 2008, 07:50:02 PM »
Do you have any type of lift?
Bob
Offline kubik1981
  • 232
Re: Fender trimming
« Reply #8 on: November 15, 2008, 08:01:07 PM »
i am running jeff's coil spring spacers, it is rubbing about half way through a turn cause i can turn it to stop and it will not rub
Offline rascott
  • 669
  • 15
Re: Fender trimming
« Reply #9 on: November 16, 2008, 12:57:42 AM »
i sprayed a light gray primer in my wheel wells after beating in the obvious rub places(rear of front wells, mostly). after a little more "fine tuning", i only get a little rubbing when i stuff the wheels.
i modified the body mounting to lift 1"+. this helped, i'm sure(and real cheap).
very little rubbing in back.
i tried 8" rims(unknow backsp.)but got more rub.
i'd think you can make yours fit ok.
Offline kubik1981
  • 232
Re: Fender trimming
« Reply #10 on: November 16, 2008, 07:42:14 AM »
thank you guys i will try when i get a day off and let you know how it goes
