T-case compatability?
  • 1734 Views
Offline biker
  • 730
  • It's a sickness I tell ya
« on: November 16, 2008, 10:55:31 PM »
I have the chance to pick up the motor, trans, t-case etc from a 96 Sport model with a 1.8, 4spd auto for a project 94 Kick I'm working on and I'm wondering if the t-case would interchange with the one I have from my 91? I want to run 4.24 gears in the case.
Thanks
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline idaholwb
  • 772
Re: T-case compatability?
« Reply #1 on: November 17, 2008, 08:08:09 PM »
 The t-case should interchange just fine. There might be a difference in output shaft spline count for the rear driveline. But the gears should interchange just fine.
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #2 on: November 18, 2008, 02:24:32 PM »
With that being a 96 tcase, the rear output shaft should have 16 splines on it versus the 26 splines found on 89-95 tcases.  Other than that they are the same (interchangeability wise) with each other.
Offline biker
  • 730
« Reply #3 on: November 18, 2008, 06:14:23 PM »
Thanks Guys
I'm planning on using my older case with a Kicker 2 adapter and Toy case. I just wanted to be sure that the tranny output and case input would match up. Are the 4spd autos reliable like the 3spd autos are?
99 Vitara 2wd
10 Gr Vitara
