98 tracker auto hubs and cv boot
  • 13 Replies
  • 3371 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: November 20, 2008, 07:40:18 PM »
stupid auto hubs wont lock, cleaned them and lubed them, sometimes I can feel it almost lock.. maybe it'll free up.  then I have to do the outer boot on the same side, is there a trick to taking the shaft out?  mystery c clip? is there a way to take auto hubs apart, I want to see if anything is broken inside
Offline idaholwb
  • 772
Re: 98 tracker auto hubs and cv boot
« Reply #1 on: November 20, 2008, 09:35:21 PM »
 If you are wheeling on auto hubs I recommend you toss them and put manuals on them ASAP! You are 100 times more likely to break your aluminum with autos versus manuals.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #2 on: November 21, 2008, 08:50:23 PM »
i know alot of people frown upon them, but for my outer boots i went to vato-zone (autozone) and bought the glue together ones, and the inners i used the ones with the lil bolt...after my lift my tracker ate my boots all up, and also SWITCH THEM HUBS!!! auto's are good as garbage...had the same issues as u with mine, so i threw 'em away and bought the 100 dollar mile markers from vato-zone as well...lifetime warranty too!!!
Offline bandit86
  • 1641
  • elv8rguy
« Reply #3 on: November 22, 2008, 04:09:02 PM »
I wheeled for 3 years with auto hubs, I loved having them, never had to change it.  sure they disengage sometime and make crunching noises, but once I figured it out it never gave me a problem.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: November 23, 2008, 08:34:43 AM »
so are all years interchangeable 89 to 98?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: November 23, 2008, 02:24:07 PM »
Offline idaholwb
  • 772
« Reply #6 on: November 23, 2008, 04:59:37 PM »
 The difference in CVs is the passenger side from 89-95 because they are 22 spline where they go into the diff. The  left side is the same from 89-98, ecvept for the Sport 4 door model.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: November 23, 2008, 07:00:53 PM »
took the shaft out, I beat the crap out of it with a 2 pound sledge for e few hours, do you think I could get it to separate?  I ended up taking the inboard side apart just to put the boot on the outter side, all 7 degrees below freezing
did match the shafts up to an earlier one i had, there is a definate difference in thickness.
how would I know if mine is a sport model?
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #8 on: November 24, 2008, 07:29:11 PM »
If it is a Tracker, it is not a Sport.  Sport is a model of the Sidekick, made in Japan.  The 1.6l Trackers and Sidekicks were made in Canada, from what I gather from this and other forums.
Offline idaholwb
  • 772
« Reply #9 on: November 24, 2008, 08:00:06 PM »
 The 4 door Sidekick Sport was a 4 door that had extra body moldings and fender flares. They had a twin cam 1.8L engine and 16" wheels standard.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Ack
Offline bandit86
  • 1641
  • elv8rguy
« Reply #11 on: November 25, 2008, 02:02:36 PM »
I know, I've done many of them but not on trackers.  usually the outer piece just slides off the shaft.  mine didnt
Offline ack
  • 1659
    • Ack's FAQ
« Reply #12 on: November 25, 2008, 05:39:48 PM »
http://www.acksfaq.com/cvhalfshaft.php
Don't MAKE me cut 'n Paste the drawing!
Grrrr....
Always concerned about the mistreatment of Suzuki parts (other than on the trail, that is   ;) ), I remain:
Ack
Offline bandit86
  • 1641
  • elv8rguy
« Reply #13 on: November 25, 2008, 06:25:33 PM »
thats fine for the inboard end, that was the side i ended up taking apart.  the outter side shold have came apart
