Learn from my mistake!
  • 10 Replies
  • 3591 Views
« on: November 21, 2008, 08:36:52 PM »
I took my 2001 Tracker LT out with a few friends to go two trackin'. I followed a 95 Pathfinder lifted 3" with 31's and a Jeep on 30's. It pulled through everything just fine, I did hit a few big rocks that I just didn't have the clearance for, but went on with no problems. Four good scrapes, but the only time a tow strap was hooked to the Tracker was pulling a stuck Rubicon from it's resting place. All went well, we went to a car wash and cleaned most of the stuff off. I didn't notice any leaks, but I did see that my drain plug had taken a hit or two. Now, being the dumb ass I am, I figured I'd just check it out later. Well, fast forward a week and guess what happened! Yup, the drain plug fell out! I had just filled up and checked the oil. Everything was fine, but I did notice a bit of a drip when I pulled away. Wasn't sure if it was there before, but I'm betting it wasn't now! About two miles down the road, my oil light comes on, I figure I'll stop at the next station a few miles away and check it out. It didn't make it :'(. I can't be mad at anybody but me, but I need my ass kicked! Questions will follow in another thread.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline jeff1997
  • 1228
  • 27
Re: Learn from my mistake!
« Reply #1 on: November 22, 2008, 03:11:20 AM »
That's alright I lost the filter on a Chevy van at about 60mph. I did not tighten it, got in a hurry. Hope it all works out.  :(
3" Masterkit1 body lift
Custom strut spacers
Offline Novadon
  • 205
  • South Carolina. USA
« Reply #2 on: November 22, 2008, 07:10:32 AM »
Doo doo happens! Don't be so hard on yourself.  ;)
I'll be following your further engine repairs in the other post, as I'll need to pull mine one day (223K miles and counting) I'm sure. I've already got another good (60K) engine in hot standby.
Good luck.
03' Honda Odyssey
« Reply #3 on: December 27, 2008, 06:41:54 PM »
For future reference, your engine's already taking damage by the time the oil light comes on. Pull over IMMEDIATELY when it goes off, and check things out... it's quite literally your last warning to stop before the engine 'blows up'.
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #4 on: December 28, 2008, 10:55:02 PM »
Novadon,
It's great that you've got that many miles on your GV.  I'm right around 170,000 on mine now (adjusting for bigger tires....the ODO reads about 160,200).  Just the other day, I noticed a small oil leak on the front passenger side of the engine.  Doesn't look too bad, but I'll have to keep an eye on it.  Would like to have the 2.7L engine dropped in when this one dies!  Take care.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline Novadon
  • 205
« Reply #5 on: December 29, 2008, 08:27:55 AM »
Yeah, I too have a small engine oil leak. Rear main I believe, or maybe the timing cover and running back. Not sure. It's not bad, but drips on to the exhaust and I can smell it more than anything. I can still go a quart down btwn changes w/o having to add oil because of it.
03' Honda Odyssey
« Reply #6 on: December 29, 2008, 10:49:28 AM »
Have you checked the distributor o-rings? They're notorious for leaking on Suzuki engines. Soaking them overnight in PB blast, or buying the replacements from your favorite online Zook dealer (about $10 to your door) should fix it.
Mine was a combination of the valve cover not being tight (closest to firewall) and the o-ring thing (I used PB Blast method, been about 2 years, and it's still fine).
Offline IanL
  • 466
« Reply #7 on: December 29, 2008, 01:51:20 PM »
I don't think that's necessarily true of the V6s.  They are basically Mazda engines with some mods.
« Reply #8 on: December 29, 2008, 05:34:14 PM »
*looks at your signature*
Heh, guess I need to get used to being in the Gen 2 area  ::)
Offline Carnage
  • 2453
« Reply #9 on: January 19, 2009, 12:41:16 PM »
least you got the picture  ;)
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #10 on: January 20, 2009, 09:54:35 AM »
First mistake. When you are cruising and the oil light comes on turn the motor off right away, If not as you seen its game over.
As for 2.0L oil leaks most comon front timing cover and valve cover rear. Ive done a few.
Im doing one last night new oil pan, new valve cover seal, rear main and front main. Oh and make sure to check the rear Crank sensor  behind the flywheel, yep has to be the best place i have ever seen one of those LOL.
01 GRAND VITARA
