Replacing Rear shocks
  • 1982 Views
Offline gil89
  • 11
« on: December 03, 2008, 06:27:42 PM »
Ok I feel like im asking a dumb question here, How do you get the rear shocks off of these things? Does the bottom bolt come out or not? seems like it is pressed in, and the top nut on the shock, any easy way to get to it?
Thanks
Eric
Offline olija
  • 770
    • Check out my cardomain
Re: Replacing Rear shocks
« Reply #1 on: December 03, 2008, 07:53:36 PM »
If it's the same as the Sidekick, and I don't see why it'd be any different, all you have to do is get a wrench on the nut on the top and use 2 wrenches on the bottom...should be pretty straightforward.
Offline gil89
  • 11
« Reply #2 on: December 03, 2008, 08:30:30 PM »
cant seem to get the bolt out on the bottom, almost looks like its pressed in, so it does come out? I guess ill put the heat to it
Offline gravity_powered
  • 43
« Reply #3 on: December 03, 2008, 10:01:42 PM »
It is more likely that it has rusted in.
Have you tried putting the nut loosely back on the bolt and belting the **** out of it with a hammer?
'98 2.5 V6 Grand Vitara
TJM Bullbar
Lightforce 170 driving lights
Wombat Racks roof rack
235/70/16 Toyo Open Country A/T
Offline bzzr2
  • 1011
« Reply #4 on: December 04, 2008, 07:02:18 AM »
i had to torch mine off the top mount after snapping one of the shocks in half...  nothing is pressed, just old fashion nuts and bolts.
09 taco reg cab short box 4x4
Offline EricV
  • 6
« Reply #5 on: December 05, 2008, 07:33:36 PM »
After taking the lower nuts off i pushed on that end of the bolt with the handle on my hammer, while unthreading the bolt from the shock with a ratchet. That worked on one of mine, on the other I had to use a cutoff wheel to expose the piece that was frozen and put a vise grip on that.
Pressing on the bolt and unthreading it from the shock with a with an impact wrench or ratchet seems to usually work. Good luck
