tyres
  • 2510 Views
Offline MBB77
  • 50
tyres
« on: December 12, 2008, 03:20:16 AM »
is it ok if i put 235/70R16 front and 255/65/R16 rear on my GV 04
grand vitara 03 V6
koni suspensions
king springs
one inch rubber over king
Re: tyres
« Reply #1 on: December 12, 2008, 05:56:59 AM »
Noy if it's a 4x4.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline bzzr2
  • 1011
Re: tyres
« Reply #2 on: December 12, 2008, 07:04:12 AM »
only if the diameter between the two tires is the exact same.
09 taco reg cab short box 4x4
Offline blacknight
  • 987
    • Gonzookin
Re: tyres
« Reply #3 on: December 12, 2008, 08:17:45 AM »
Noy if it's a 4x4.
This also may mess up the ABS if you have that too.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: tyres
« Reply #4 on: December 12, 2008, 11:39:49 AM »
Noy if it's a 4x4.
Man, that's a good point.  It definitely noticed when I went with a stock-sized spare for a while.
XL-7 front coils
1.5" rear coil spacers
Offline MBB77
  • 50
Re: tyres
« Reply #5 on: December 12, 2008, 11:41:04 PM »
thanks for your replies
the tyre 235/70 is 164.5 and 255/65 is 165.75
so what doyo think
grand vitara 03 V6
koni suspensions
king springs
Offline IanL
  • 466
Re: tyres
« Reply #6 on: December 14, 2008, 02:47:54 AM »
Only ok for 2WD.
If you try 4WD, even on very loose surfaces, the tires will be constantly slipping because of the different speeds, so you will get no traction improvement at all.
Offline MBB77
  • 50
Re: tyres
« Reply #7 on: December 14, 2008, 03:20:02 AM »
thanks for your reply
i'll go to 235/70 only
grand vitara 03 V6
koni suspensions
king springs
