96 Tracker Front Diff. Madness
  • 15 Replies
  • 7365 Views
Offline zukizuki07
  • 251
« on: December 14, 2008, 03:25:52 PM »
Alright guys heres the scoop, I finally got time to go check my tracker out today and what do you know my cv's are spinning freely and loosely in my front diff.... cv's seem fine, my question is, does anyone have a writeup or just some time to explain the vitara steel diff. swap, and what ill need, and also any info on possibly throwing a front axle assembly from a samurai I have access to... this is Diff. # 2 now... and they are getting hard to find in my area for a decent price.....
5 speed
2 door
thanks - josh
96 2 Door Tracker
Offline zukizuki07
  • 251
Re: 96 Tracker Front Diff. Madness
« Reply #1 on: December 14, 2008, 07:35:25 PM »
wow I picked a Bad night to ask a question! haha tons of Q's tonight!
96 2 Door Tracker
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: December 14, 2008, 08:07:45 PM »
This is the info that you are looking for:
http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htm
...and it's here at ZukiWorld.com!
Ack
Offline zukizuki07
  • 251
« Reply #3 on: December 15, 2008, 12:41:15 PM »
bookmarked, thank you very much!
96 2 Door Tracker
Offline zukizuki07
  • 251
« Reply #4 on: December 15, 2008, 12:54:36 PM »
Next question, Will that 3rd member work on my 96??
96 2 Door Tracker
« Reply #5 on: December 15, 2008, 04:33:48 PM »
I'm thinking of doing a toyota front anvil, and running yota CV:
http://www.pirate4x4.com/forum/showthread.php?t=318480
« Reply #6 on: December 15, 2008, 06:12:22 PM »
I am converting a Sammi rear end into a front housing for my tracker diff.  Everything went together exceptionally well.  I had to special order one of the seals (the other seal and bearings are the same as the trackers, and have just received the parts to put my tracker gears into Sammi diff.  Changing the crush sleeve is more daunting than building the modification.
On the right is my new front diff housing.
« Reply #7 on: December 15, 2008, 10:26:13 PM »
I don't think I've ever seen this done before! Brilliant! If you want to get really crazy, chop both sides, center it, and make long-travel IFS :)
« Reply #8 on: December 16, 2008, 08:27:34 AM »
Great, now I'm trying to think of how far inboard you could mount the A-Arms without running into complications with the engine...
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #9 on: December 16, 2008, 10:25:26 AM »
I've thought about doing this also.  Even though I an Anvil up front and the 5.83 gears, the rear is stock (busted one axil already).  If I went with a yota axil in back and up front, I would have a stronger rear end (larger tires) and more options for gears and lockers.
Has anyone tried the Calimini upgraded axil shafts?
32 MTR's Warn 8000i
Offline suva
  • 35
« Reply #10 on: December 16, 2008, 12:53:34 PM »
I like that one a lot, without uppers you could have the lower arms damn near touching- or maybe crossed.
Wait, didn't Ford do something similar?
Offline zukizuki07
  • 251
« Reply #11 on: December 17, 2008, 12:01:34 AM »
Broncos are similar to that
96 2 Door Tracker
Offline Bunker
« Reply #12 on: June 30, 2010, 09:13:29 PM »
I have  94 geo tracker and I was wondering if a 96 front diff will fit in my 94 .. or is it wider. I need to know cause i have a Calimini Anvil and now I have to find a 96 Vitara/Grand Vitara front to work with that... Help pls studnb|removethispart|@hotmail.com 7809967179
thanks WEs
« Reply #13 on: June 30, 2010, 09:21:24 PM »
Yes they will interchange, not sure if the Sport will to regular track/kick
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #14 on: June 30, 2010, 11:25:13 PM »
Yes, it does.
