Front on Gv higher than 3inchs
  • 10 Replies
  • 3714 Views
Offline 1GV
  • 52
« on: December 17, 2008, 03:11:27 AM »
Hi All
so i have lifted the GV as high as i can go, well sort of - i know from playing with the rear suspension that i can make it a 5 inch lift ( 4inches now ) but has anybody gone over 3inches in the front?? if so what have you done??
i have fitted struts, springs and diff drops in the front for a 70mm lift and i want to go higher but without welding things on
thanks for any input
Tim
Offline 1GV
  • 52
Re: Front on Gv higher than 3inchs
« Reply #1 on: December 21, 2008, 02:35:04 PM »
no replies!! must be  secret ???
Offline dentedzuk
  • 171
« Reply #2 on: December 21, 2008, 06:11:10 PM »
or under development..http://www.zukination.com/suspension.htm (look halfway down the page) :o
2001 2.0L 4dr Vit: Calmini 2.5" susp, 215/65R16's, Surco safari rack, cone filter, turbo muffler!
***FOR SALE***
2" R.R.O. B/L w/ steer extension - $125
Trackkick axle, $50
stock Vit springs - $50
2x 225/75R16s A/Ts(95% tread) -$85
pics- http://www.zukiworld.com/forum/index.php?topic=24765
Offline blacknight
  • 987
    • Gonzookin
« Reply #3 on: December 21, 2008, 08:22:16 PM »
that's been "under development" for some time.  4" is the highest kit that I've seen to date.  You stated that you are at  70mm = 2.75in.   Was this a kit or just springs and a diff drop.
Offline 1GV
  • 52
« Reply #4 on: December 22, 2008, 01:14:11 AM »
struts, shocks and diff drop
« Reply #5 on: December 22, 2008, 01:37:12 AM »
As long as you keep dropping the diff to make sure the CV angles don't get too crazy - you can go as far as you want. The limitation becomes the angle of the front shaft from the t-case to your front anvil (aka diff). I've seen a 7" lift on a 4-door tracker done this way - the guy just dropped the whole suspension down. More complex than a body lift, but he got more frame clearance  :D
Out of curiosity, what size tires are those? What engine do you have? How has your power & MPG been impacted with the bigger rubber? Do you live in flat ground, or in the hills?
Offline blacknight
  • 987
    • Gonzookin
« Reply #6 on: December 22, 2008, 11:27:58 AM »
Another issue with GV and Xl's is that they have rack and pinion steering. The whole rack would need to be dropped as well.  At 4" I think you would be pushing it but could get away without dropping it but your going to need space the tie rod ends out some. Also the rear track bar will need to be address too.
Offline 1GV
  • 52
« Reply #7 on: December 22, 2008, 11:30:49 AM »
well i get 70km less per tank if i drive normaly  :laugh: and mostly i get about 400km out of a tank.
tyres are 225/75/16 and its a 2.5V6 04 model.
rear is good with panhard rod relocation bracket.
« Reply #8 on: December 22, 2008, 11:52:43 AM »
Does that include the amount your odometer is off because of the bigger tires?
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline olija
  • 770
    • Check out my cardomain
« Reply #9 on: December 25, 2008, 05:07:11 PM »
I wouldn't count on the ZukiNation 4" kit coming out for quite a while. I phoned them back in October to inquire if it would be done by New Year's and they said it had been put on hold for an indefinite amount of time because they are/were in a temporary warehouse and they wouldn't be able to work on it for some reason or another. I was disappointed, I really didn't want to have to body lift my new Zuk to fit 31's.
Offline MBB77
  • 50
« Reply #10 on: January 04, 2009, 02:38:29 AM »
can you show me the photo of this blue part?
grand vitara 03 V6
koni suspensions
king springs
one inch rubber over king
