dim headlights
  • 3514 Views
Offline mfoster442
  • 29
dim headlights
« on: December 27, 2008, 04:28:13 PM »
greetings.
The headlights on my 2002 Vitara (2.0L, no mods except Boondox lif) seem very dim.  is this a function of the bulbs I'm using, or is there just only so much power the system can put out?
Any suggestions are appreciated.
Thanks.
2002 Vitara
235/70/R16 Cooper Discoverer S/Ts
Stock engine and running gear
Boondox Spacers
Pro-Comp Shocks Strut extenders Camber bolts
Re: dim headlights
« Reply #1 on: December 27, 2008, 05:54:45 PM »
My gen 1 (1996) is the same way. I'm wondering if the bulbs are just nearing the end of their life or something?
Offline Armour
  • 360
Re: dim headlights
« Reply #2 on: December 28, 2008, 02:16:53 PM »
I would check alternator output or bad/ corroded powers and grounds for the headlights!
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
Re: dim headlights
« Reply #3 on: December 28, 2008, 10:47:01 PM »
From what I understand, halogen bulbs get dimmer and dimmer over time.  I have Sylvania Silverstar Ultras in my truck, and they do a really great job.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Re: dim headlights
« Reply #4 on: December 29, 2008, 10:15:04 AM »
greetings.
Thanks.
I have had success with using plastic polish on the housings, and I have adjusted my beams higher than factory.  Oncoming traffic has not complained so far.  But no load on hitch.  25-50 dollar pairs of bulbs are much brighter, esp the white light as opposed to xenon or ?????.  I have noticed a shorter life span with the newer lamps.
Pat
Offline olija
  • 770
    • Check out my cardomain
Re: dim headlights
« Reply #6 on: December 29, 2008, 04:40:05 PM »
I got some Silverstar XT's in both my Sidekick and Vitara. They are both VERY good in terms of brightness.
Offline Armour
  • 360
Re: dim headlights
« Reply #7 on: December 29, 2008, 04:56:43 PM »
I've been looking at "Hella" lamps. They have "driving" and "fog" lamps - what's the difference?
http://www.amazon.com/Hella-HLA-H13750601-Model-Driving-Lamp/dp/B0002M9TQW/ref=sr_1_2?ie=UTF8&s=automotive&qid=1230576322&sr=1-2
http://www.amazon.com/Hella-HLA-H13750611-Model-500-Lamp/dp/B0002M9TRG/ref=pd_bxgy_auto_img_c
The difference is in the distance and pattern of the light! A driving light will shine further with a narrow pattern! Typically around 30 degrees. Where as a fog will shine wider with a 60 degree pattern. Fog lights usually run a bit lower wattage also!
Offline mfoster442
  • 29
Re: dim headlights
« Reply #8 on: December 30, 2008, 09:48:26 PM »
I'll try some new bulbs, polish the oxidation/cloudiness off the covers and check the connections.  I'm glad to hear that it seems there's no flaw in the design or that the system is just weak.
Thanks for all the suggestions.
2002 Vitara
Boondox Spacers
