Painting tip!!
  • 1850 Views
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
Painting tip!!
« on: December 28, 2008, 06:50:54 PM »
I have a converrtable 97 kick, and i just bought a hard top for it....
My problem is, that i want to paint it.. could someone tell me how to do it??
thanks
Offline ranger88den
  • 279
Re: Painting tip!!
« Reply #1 on: December 29, 2008, 06:16:45 AM »
I would contact a professional automtive paint supplier to see what is compatible.  Good luck
Offline hegemon
  • 112
Re: Painting tip!!
« Reply #2 on: December 30, 2008, 11:54:52 AM »
Depends on the condition of the top, and your end goal.
The top is most likely fiberglass, and is already painted.  If you wanted to rhino line it (bed liner), simply scuff up the paint with 800 grit, clean it well, and spray/roll on the bed liner.
If you want to actually get a more glossy/automotive finished look then the key is in the sanding process.
Assuming the top is in good shape, you could start with an 600 grit paper and again scuff up the existing paint, and smooth out any imperfections.  Depending on the shape of the top, you may need to start with a lower grit, 400 should be able to sand off any major imperfections.  Then start with a basic automotive primer you can get a "buildup" primer if there's a lot of areas that need covering up.
Give it two coats primer, allow a few minutes in between to dry, then sand it again with 800 grit paper, clean it, and give it another couple coats of primer, repeat process if needed.
You should have a nice an smooth surface now that is now ready for paint, you can use a standard rattle can and get a pretty good finish, again it's all about the sanding.  Give it two coats of paint, let it dry and then wet sand it with 1000, or 1200 grit to remove any runs.  Give it a couple more coats of paint, you may need to sand again with 1500 grit paint, another coat of paint, and a final sanding of 2000 grit paper.
Once complete, you can start applying some clear coat, same process, but start with a 1500, and finish with 2000, for an ultra finish, you can finish it off with a rubbing compound, and a nice coat of wax.
There's a lot of manual labor involved with painting on your own, but if you have the time and patience, then you can achieve a nearly professional looking job.
Personally, I would do the initial prep and primer, then take it to Maaco for painting.  Most of the "cheap" paint shops are fine painters, they usually don't put the time into the prep work, this is why they can paint for cheap.
Re: Painting tip!!
« Reply #3 on: December 30, 2008, 02:22:22 PM »
Painting is 90% prep work & clean paint area (Dust = bad) - and that's where all the labor is. Google is going to be your friend when it comes to DIY painting. Rattle cans work just fine... as long as the prep is good.
Rattle can Tip:
Warm up the cans before use. Some people use hot tap, or microwave the water. I've had good success with putting hot tap into a slow cooker (crock pot) on low. Leave the cans in there when you're not using them, and it'll keep the paint warm - which makes the paint come out smoother.
And - invest in a respirator. Seriously. It's $70 to save your lungs, and will last you a lifetime if you're just doing home jobs every couple years.
Offline hegemon
  • 112
Re: Painting tip!!
« Reply #4 on: December 31, 2008, 06:38:57 AM »
Nice tip on warming the paint, never even considered it!
