What fluids do u use? Post them up
  • 14 Replies
  • 3710 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: September 07, 2004, 04:45:51 AM »
Just wanted to know what fluids u guys use in ur diff's and transfer cases and rear ends and so forth.
Im gonna change mine was thinking of using 75w90 pensoil sythetic in the rear diff and front diffs with some lucsas additive in them???
01 GRAND VITARA
Offline hcgalvin
  • 1695
    • Granite Path
Re: What fluids do u use? Post them up
« Reply #1 on: September 07, 2004, 05:19:08 AM »
80/90 Valvoline in differentials and tranny.....
85/140 Valvoline in tcases...
I haven't put synthetic in, but I should.
I run 10/30 semi-synthetic (Quaker 4x4 oil) in my engine.
:P
Heather Galvin
spinaltap
« Reply #2 on: September 07, 2004, 06:42:21 AM »
No need to put Lucas additives in with synthetic gear oil, its probably not even recommended. I run synthetic in the diffs/tranny and transfer case. Shell Rotella (dino) 15/40 with Lucas additive in the engine.
« Reply #3 on: September 07, 2004, 07:02:49 AM »
Miller Light,
1800 Tequila
Segrams 7,
Mountain Dew AMP (crack in a can ;D)
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: September 07, 2004, 09:58:45 AM »
Miller Light,
1800 Tequila
Segrams 7,
All of this just to lube the loose nut behind the wheel?  ::)
:o :o :o :o :o :o :o :o :o :o
Offline jerryp58
  • 449
« Reply #5 on: September 07, 2004, 10:39:13 AM »
I'm running crude right now but have thought about synthetic at least for the diffs & TC; I doubt I'd ever run synthetic in my 155K auto, but would if I ever rebuild or replace it.
Anyone have any comments about switching to synthetic: pros/cons?  I know some people swear everything runs quieter and some have claimed improved MPG.
Jerry
Offline EdgeXBros
  • 9
  • Edge Bros Samurai Parts
« Reply #6 on: September 07, 2004, 10:48:06 AM »
I use the Royal Purple line in my Samurai's Differentials, Transfer Case and Transmission; all synthetic. It hasn't let me down scince.
Edge Bros Aftermarket Samurai Parts
Contact: Edge_Bros|removethispart|@Hotmail.com
Offline Mike71
  • 1449
« Reply #7 on: September 07, 2004, 11:51:23 AM »
hahaha that was great! lol..can u feel the love LOL
Offline szabotage
  • 114
  • snaggletooth
« Reply #8 on: September 07, 2004, 11:52:03 AM »
bottom of the line crappy tire gear oil but I replace it frequently since i do alot of mud and water crossing,
crappy tire 10W 30 in the crankcase every 3000k
that's the samurai for ya
in my turbo'ed 323 I use castrol 10W30 with a litre of synthetic, mobil 1 or castrol syntec. nothing but the best
« Reply #9 on: September 07, 2004, 11:58:33 PM »
;D ;) ;D
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #10 on: September 08, 2004, 02:08:40 AM »
I run Mobile synthetic in dif's and tranny.  I use the 5w30 in the crankcase since I can't brake the crankshaft nut to replace the leaking seal.  Any suggestions on how to do this?
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline EdgeXBros
  • 9
« Reply #11 on: September 08, 2004, 02:44:02 AM »
Get a 90 90 wrench ( where the heads are 90* to the wrench body) and a breaker bar. That should do you fine.
« Last Edit: September 08, 2004, 02:44:28 AM by EdgeXBros »
Offline brace
  • 264
« Reply #12 on: September 08, 2004, 02:53:01 AM »
Don't you have to lock the flywheel?
« Reply #13 on: September 08, 2004, 06:36:40 AM »
on breaking the nut loose, try heating it up good with torch but not too hot where you fry the rest of the seal, then let it cool over night and try to loosen it in the morning, put it in fourth gear and block the tires, the next thing would be to try a small impact on it on low, if you have room you could hit the head of the bolt with an air hammer a couple of times to shock the threads, and last drill a small hole in it and put some liquid wrench through the hole and let it set a while, then repeat if not off yet ;D
Offline greaseguncutts
  • 10
  • Turn left. NO YOUR OTHER LEFT. Ok whos got a winch
« Reply #14 on: September 08, 2004, 01:40:54 PM »
I just did mine I used a 1/2 inch impact no problem getting it off. I am using an impact that says Matco Tools on it but  i is still made byr IR.
DC 126*925*11205
If you are on Nextel Beep Me.
Michael Cutts
