how strong is a sammi t-case
  • 2063 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« on: December 30, 2008, 06:22:35 PM »
this is a subjective question. however i am planning to build twins trackers on hp44s and a 9"s with 40" tires will a sami case stand up to this. any thoughts? it will run tracker auto running gear to a kicker3 to a sammi case with a gear reduction, 5 somehting ratio in axles locked. i have no experuiance with sammi cases strength i would like to use it do to the high range reduction. i have biuld several rigs and currently have a grand cherokee on 38.5 swampers with the same axle setup i am capable of the build. they will be multi link with fox single rate air shocks.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Re: how strong is a sammi t-case
« Reply #1 on: December 30, 2008, 06:50:18 PM »
Some people make a ring that bolts all the way around it - Rock Rat makes & sells one. Other people use the mighty kong to give extra strength, and others use both...
The case will survive most use, but some people are hard on them and do crack the cases. When I go dual, I will be adding a little protection of some kind because I'm paranoid.
Offline tracker8wr
  • 568
    • my home page
« Reply #2 on: December 31, 2008, 11:54:27 AM »
thanks for the input. i know thre are some more sammi guys out there. any input?
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline minimudder87
    • Sinizter Customs
« Reply #3 on: January 02, 2009, 09:32:53 PM »
i broke mine doing 4 low wheelies lol but took it out and made my own mount to tie both sides together and so far so good
