Ford Wheels?
  • 3154 Views
Offline drewler
Ford Wheels?
« on: January 01, 2009, 03:34:19 PM »
I've read that some Ford wheels will fit Tracker/Vitara's.  I'm looking for a second hand set of wheels that are spaced out .5-1 inch more than stock, preferably one's that look good.  Does anyone know what Make, Model, and year I should be looking for?  I have a 02 Tracker.
Thanks.
Offline Armour
  • 360
Re: Ford Wheels?
« Reply #1 on: January 01, 2009, 04:26:02 PM »
i am pretty sure that late nineties to early 2000's had 5x5.5 bolt pattern. just have to make sure the center hole is big enough!
Offline sir lance
  • 342
  • I love my XL-7
Re: Ford Wheels?
« Reply #2 on: January 02, 2009, 12:35:47 AM »
i used (1995 ish i think, its been too long now) f150 wheels on mine, but i had to plasma cut the center hole out about 1/8" all the way round
-Lance
Offline toofaroffroad
  • 226
Re: Ford Wheels?
« Reply #3 on: January 02, 2009, 12:34:21 PM »
 1995 and older will fit Suzuki. 1996 and new switched to metric...I found that out the hard way.
older bronco, f-150 etc etc should fit.
Offline olija
  • 770
    • Check out my cardomain
Re: Ford Wheels?
« Reply #4 on: January 02, 2009, 09:17:17 PM »
-Lance
Hey Lance, I actually bought those rims off some guy around a year and a half ago. The offset was real nice but man did they shake on the freeway because of that plasma cut job.
I DO NOT recommend these wheels to anyone using their truck as a daily driver. I also think that it depends which truck it is off of though because I have heard of alot of other people running Ford Bronco and F-150 rims on their Sidekicks. Make sure it fits!
Offline sir lance
  • 342
  • I love my XL-7
Re: Ford Wheels?
« Reply #5 on: January 04, 2009, 11:09:03 PM »
i would try the bent rim being the cause ;), the center hole doesnt center the rim on the hub, the taperd lug nuts do
we never had an issue with them, smoothe as silk
-lance
Offline olija
  • 770
Re: Ford Wheels?
« Reply #6 on: January 05, 2009, 06:48:47 PM »
Hmm I never noticed any bent rims when I balanced them...weird. Don't worry, I bought some CJ rims and they were bent too. Now I'm buying some NEW rims so I won't have to worry about that anymore!
Offline jeff1997
  • 1228
  • 27
Re: Ford Wheels?
« Reply #7 on: January 05, 2009, 07:20:42 PM »
I have a set of plain steel 15" Ford truck rims that fit and I' pretty sure the center is big enough also. I got them to run on the Sport but 15's won't fit. I'm in IL if anyone wants them.
3" Masterkit1 body lift
Custom strut spacers
Offline sir lance
  • 342
  • I love my XL-7
Re: Ford Wheels?
« Reply #8 on: January 06, 2009, 12:38:30 AM »
candace blew a tire out while coming down an obsticle and bent one of the rims in the prosses.
-Lance
