Wheel spacer + negative offset rim question
  • 1873 Views
Offline olija
  • 770
    • Check out my cardomain
« on: January 08, 2009, 07:48:23 PM »
Hello all
I have a basic question for you wheel gurus...if I have a 7" rim with 3.75" of backspacing, and choose to use a 1" wheel spacer, what backspacing do I need to switch to to get the same amount of tire sticking out of the fender? Is it 4.75 or 2.75? Thanks
Offline MUD CHILD
  • 355
  • 9
Re: Wheel spacer + negative offset rim question
« Reply #1 on: January 08, 2009, 09:42:54 PM »
2.75 and that will give you the same amount of tire sticking out as with the wheel spacers, that's if you stay with a 7" rim
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline 2K1USGV
  • 218
« Reply #2 on: January 08, 2009, 09:53:59 PM »
WHat's the point of the wheel spacer if you want to retain your current track width ?
Offline olija
  • 770
« Reply #3 on: January 11, 2009, 04:20:02 PM »
I need the 1" spacer to fit a 15" rim on a Vitara. 15" rims only fit on the Trackers without any help. Thanks for the help, guys.
