1.6 power?
  • 2400 Views
Offline Dazookster
  • 61
1.6 power?
« on: January 09, 2009, 07:21:45 AM »
I was wondering what are the power ratings of the 1.6 8 valve, 1.6 16 valve, and the stock Samurai engine? Torque and HP.Thanks.
Wahoo for Global Warming more time to go Wheeling
Re: 1.6 power?
« Reply #1 on: January 09, 2009, 09:18:50 AM »
The Sammy depends on your market, the numbers I have is 65hp/69lb.  But it changes from place to place/documentation.
I believe the 16v is 95hp/94lb?.  Not sure on the torque, but it is close to the hp rating.
Re: 1.6 power?
« Reply #2 on: January 10, 2009, 06:14:35 AM »
1.6 8V is 80bhp +/- a couple.
Re: 1.6 power?
« Reply #3 on: January 13, 2009, 11:12:03 AM »
If you're thinking about engine swaps, the hot new thing is the 2.0L - not much more $$$, but 30% more HP & torque (about 135 hp & ft lbs). Sean Devinney has a kit over at aftermarket4x4.com
He also has a writeup if you want to read and do it on your own.
Offline urbanwheeler
  • 696
Re: 1.6 power?
« Reply #4 on: January 14, 2009, 01:37:58 AM »
and still sounds like the 1.3 :D
Offline Dazookster
  • 61
Re: 1.6 power?
« Reply #5 on: January 14, 2009, 08:34:55 AM »
I have an idea I was thinking about putting a mild cam in the 8 valve 1.6 how would that compare to the 16 valve?  I'm sure it would make it torquey which would be nice for the trail and highway.  Is anyone here running a mild cam in either there 1.3 or 1.6 is it alot better than stock?
Re: 1.6 power?
« Reply #6 on: January 15, 2009, 07:04:22 PM »
Cams / timing changes just move the HP & Torque up and down the RPM range. You'll technically get less HP & Torque (by the conventional measurement of "peak" power), but if you move the HP & Torque to where it's more useful... then who cares?
