Transmission Rebuild - Done!
  • 1744 Views
Offline pershingd
  • 45
« on: January 18, 2009, 03:59:00 PM »
Finally got the Tracker out of the garage for the first time since New Year. Even though it took much longer than I had planned, I am psyched about the results. I didn't realize how much noise the transmission was making until I took it on it's test ride. Not only is it quieter, it feels like its pulling up the hills much easier than before. Maybe I'll grab a few more MPGs as a result.
Was it more cost effective than finding a low-mileage used one? If you don't count the cost of a couple of tools and the down-time, it was much cheaper. When you factor those in, I'm not so sure. I ran into more than just bearings and synchros when I needed to locate a new input shaft. The new input shaft prompted me to look closely at the pilot bearing which led to a clutch kit.
After I got it back together, I had a few problems from it sitting in the garage for a few weeks. I live out in the woods and have a problem with the native wood rats out here. Well, they got into the heater and filled the blower motor up with all sorts of stuff. It took me nearly 4 hours to clean it all out. Then I noticed they got the wiring for my fog lights and the right side turn signal. A couple of hours this morning and I got that fixed.  Lets not forget the tire that went flat.
The question is - would I do it again? Probably. The way I look at it, I KNOW that I have new bearings & synchros installed and that should last me another 170,000 miles. Anyone can say a used transmission has low mileage, but can you really tell for sure? That said, this is not a job for the feint of heart. There was a number of times that I had to ask myself what was I thinking, but I stuck it out and got it done.
Thanks go out to Frank84 for his support and assistance.
David
2001 Chevy Tracker (2 door, 2.0L, 5 Speed - itching for a lift)
1999 Ford E-350 Super Duty (15 passenger, 6.8L V-10)
Offline Frank84
  • 176
Re: Transmission Rebuild - Done!
« Reply #1 on: January 20, 2009, 04:55:40 AM »
Once again I read my PM's before the posts.  Congrats on getting it back on the road!
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
