Brake Bleeding Procedure? GOING CRAZY!
  • 1990 Views
« on: January 18, 2009, 07:02:29 PM »
I am going crazy! I had an issue with my brake master cylinder losing pressure and the pedal sinking at stop lights. So, I bought one on ebay, installed and bled then the same problem started happening.  SO, then I bought a NEW MC and the same thing... Is there a trick with the bleeding procedure? I think I am losing pressure. I checked for vacuum leaks and could not find one... Has anyone run into this? PLEASE HELP!
Offline scuzzuk01
  • 10
  • forgot my outboard motor
Re: Brake Bleeding Procedure? GOING CRAZY!
« Reply #1 on: January 18, 2009, 07:12:02 PM »
Did you bench bleed the master cylinder before installation??  If not, you will continually push air from master cylinder to the wheel cylinder/calipers.  Once you get it bench bled, go to passenger side front wheel, then passenger side rear wheel, then driver side rear and finally driver front.  ALWAYS make sure your reservoir is topped off.  The reservoir on these things are TINY and require constant attention!!
Good Luck
A work in progress, 88.5 with a 4"spoa, over the top steering, 31" BFG A/T's, 500 watt pioneer stereo and a slight quarter panel ding from Hurricane IKE..... Stock 1.3 and a modified side-out straight pipe exhaust.
« Reply #2 on: January 18, 2009, 07:44:05 PM »
The instructions were very clear not to bench bleed this MC... it is a 1995 4 Door... there were multiple tags saying not to bench bleed with BOLD letters. Also, the rear is daisy chained... I thought you start at the furthest from the MC... is that not right?
« Reply #3 on: January 19, 2009, 09:03:06 PM »
Found the procedures for the specific model and specs... bled as instructed and still losing pressure... Ugh
Offline Armour
  • 360
« Reply #4 on: January 19, 2009, 10:35:09 PM »
The only other thing it could be in theory is a external leak! I would say go over your rig again and check for leaks.
Offline SNJSamurai
  • 386
« Reply #5 on: January 20, 2009, 12:20:08 AM »
or a warn rubber lines thats expanding when ur pressing the brakes
its pretty common with all cars some times they just dont hold up
also u are right mallard generally u bleed brakes furthest from the mc. unless factory but rarely says a different way
Bob
