Steering???
  • 10 Replies
  • 2873 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Steering???
« on: January 24, 2009, 04:55:56 PM »
I have an 01 Tracker 2.0 with power steering and have recently started getting a "tight" spot in the steering just off center in both directions. I have had the front end checked out and an alignment done and it got a clean bill of health but this problem showed up since then. I'm wondering if others are having problems with theirs or if I'm correct in saying that the problem lies in the steering rack. I only have 130,000kms on the truck and feel that this is a bit premature.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Re: Steering???
« Reply #1 on: January 24, 2009, 07:58:53 PM »
Offline biker
  • 730
Re: Steering???
« Reply #2 on: January 25, 2009, 08:06:52 AM »
I think you better step away from the pipe as last time I checked 2001 fell between 1999 and 2005.
Anyone have anything to contribute on the question in the first post?
99 Vitara 2wd
10 Gr Vitara
Offline pershingd
  • 45
Re: Steering???
« Reply #3 on: January 25, 2009, 08:15:30 AM »
I'm sure you don't want to hear this, but I suspect the steering rack is going bad. I've had this occur on a couple of other cars and each time the rack was to blame. Check the pump & fluid, but I'm betting the rack needs to be replaced.
David
2001 Chevy Tracker (2 door, 2.0L, 5 Speed - itching for a lift)
1999 Ford E-350 Super Duty (15 passenger, 6.8L V-10)
Re: Steering???
« Reply #4 on: January 25, 2009, 02:57:05 PM »
Oh.....
I was in the wrong forum  :-[
*puts the crack pipe down*
Offline Frank84
  • 176
Re: Steering???
« Reply #5 on: January 26, 2009, 04:44:25 AM »
Check the joints in the steering shaft where it connects to the steering rack.  You'll have to unbolt it and then check them to see if they are binding up.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline biker
  • 730
Re: Steering???
« Reply #6 on: January 26, 2009, 09:04:51 PM »
Thanks guys, it's kinda what I thought. Have to wait for warmer weather to get a better look at it.
99 Vitara 2wd
10 Gr Vitara
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Steering???
« Reply #7 on: January 31, 2009, 04:41:53 PM »
Biker, out of curiosity, anything unique about your truck, like suspension modifications or running larger tires?
Offline biker
  • 730
Re: Steering???
« Reply #8 on: February 02, 2009, 05:19:27 PM »
Truck is bone stock.   Got a chance to have a closer look and found one of the U-joints just above the steering rack is seized. You can't buy just the joint you have to get the lower shaft. Can't seem to find one in western Canada for a decent price, even used they want $150 so I called Hawk and they hooked me up on the cheap.
A new one in the US is $300 or so but in Canada it's $637, anyone got any kinda justification on that  anal raping that we seem to be subjected to up here. >:(
99 Vitara 2wd
10 Gr Vitara
Offline bzzr2
  • 1011
Re: Steering???
« Reply #9 on: February 03, 2009, 07:13:15 AM »
one thing with the new parts here is i have found that if i go between suzuki, chevy and aftermarket there is usually one that stands out as significantly cheaper, however it is never consistent as to who has the best pricing.......  bs really.
09 taco reg cab short box 4x4
Offline biker
  • 730
Re: Steering???
« Reply #10 on: February 03, 2009, 06:53:16 PM »
Several times I have bought "dealer only" parts from GM only to find a Suzuki part tag under the GM one, but yet GM is usually cheaper?  Hawk was AWESOME to deal with and gave me a good price on the part :)
99 Vitara 2wd
10 Gr Vitara
