advice on fitting 33s
  • 1479 Views
Offline mersingt
« on: January 25, 2009, 07:16:57 AM »
Alright ive got a 96 2 door convertible with a 3 inch bodylift and 4 door springs running 31 inch tsl radials...Im planning on getting a samurai tcase dropped in sometime in feburary and locking the rear end also  with this setup the goal is 33s I plan on purchasing ome struts and running crown vic shocks in the rear (already installed)
so for the front Im looking at a 1.5 inch spacer which should give me about 1.75 inch of lift and doing the same for the rear cause my front is droopy then of course trimming the back of the front wheel well and the rear as required...
eventually Id like to do some gv v6 coils all around or a calmini 3 inch and gear the tcase to run 35s
do you think that what I have now is sufficient?
96 geo tracker 2 door
31" tsl radials
3 inch calmini
4 door springs
Offline RACER X
  • 383
  • zuki or die!
Re: advice on fitting 33s
« Reply #1 on: January 25, 2009, 09:32:53 AM »
ive got 3in body lift, 2inch spacers and 4dr coils
 im running 33x12.5x15 with minior trimming on ford rims
98 kick
Offline jeff1997
  • 1228
  • 27
« Reply #2 on: January 25, 2009, 12:22:03 PM »
mersingt, I can make any size spacer from 0-2.5" that you may need. PM if interested
3" Masterkit1 body lift
Custom strut spacers
