Lucas
  • 26 Replies
  • 6778 Views
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Lucas
« on: January 25, 2009, 01:48:57 PM »
My truck has only been driven on the weekends since December and will only be driven on the weekends up until April. The lifters would rattle on start up, until I started using Lucas synthetic oil stabilizer. Now when it fires up I get no rattle. Great stuff.
Offline blacknight
  • 987
    • Gonzookin
Re: Lucas
« Reply #1 on: January 26, 2009, 07:13:38 AM »
what type of oil are you using? As my Xl will no longer be my DD and I don't want to have the same issues.
George
Re: Lucas
« Reply #2 on: January 26, 2009, 08:49:51 AM »
Posted by: 97TRAKIN
Insert Quote
XXXXXXXXXXXXXXXXXXXX
SO, I tried the Lucas oil in the crankcase at last oil change.  Seems to NOT help (far as I can tell) the sticky lifter noise.  The oil level at full does seem to help a great deal.  These things are very sensitive to liube levels.  Weather has an effect also, with cold temps being tougher.
Pat
Re: Lucas
« Reply #3 on: January 26, 2009, 12:15:42 PM »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Lucas
« Reply #4 on: January 26, 2009, 01:20:43 PM »
The oil level at full does seem to help a great deal.  These things are very sensitive to lube levels.  Weather has an effect also, with cold temps being tougher.
Pat
X2.  Plus, make sure you're running the mfr recommended 5W-30, nothing heavier, especially in cold weather.
XL-7 front coils
1.5" rear coil spacers
Offline Carnage
  • 2453
Re: Lucas
« Reply #5 on: January 26, 2009, 01:30:04 PM »
I would be interested in more lucas studies
i mean theres a little oil gear advertisement stand in every checkers ive been in
seems to me they wouldnt make something that didnt work
(if not a tiny bit)
Re: Lucas
« Reply #6 on: January 26, 2009, 06:32:15 PM »
People that make things that don't work all the time. And people buy those things all the time - on the assumption that they "must work", or they wouldn't be selling it. There's lots of studies about oil additives out there. Most of them say the same thing: Messing with the BALANCE that oils detergent packages MUST have to work properly does more harm than good. There's exceptions - like oil additives that clean the engine, but that's because they're only supposed to be run for a very limited amount of time (usually under 100 miles), so they don't have time to do any harm.
All the info you need is on the site I linked. It gets into the why's and what-for's of oil. What detergent packages are, why they're there, what they do, how long they last... and more.
Offline 97TRAKIN
  • 600
Re: Lucas
« Reply #7 on: January 31, 2009, 04:54:20 AM »
I was and still am very cautious about oil additives. I think if it was to be in the oil it would have already be in there. The ticking on start up after my truck sits for the whole week (not just over night)  was driving me up the wall. I found something that worked for me and thought I'd share my finding that all. And by the way its the 'Synthetic Lucas' I use not the regular one.
Offline IanL
  • 466
Re: Lucas
« Reply #8 on: February 01, 2009, 02:17:58 AM »
You could be right that the Lucas helped, but how can you be sure that the same amount of plain synthetic oil would not have done the same (that's assuming the level was a bit low)?
Offline 97TRAKIN
  • 600
Re: Lucas
« Reply #9 on: February 01, 2009, 05:30:38 AM »
I never said that the same amount of synthetic oil wouldn't have worked. I used the Lucas when I did the oil change and it worked and has been working, so I posted my findings. ;) ;)
Offline Carnage
  • 2453
Re: Lucas
« Reply #10 on: February 06, 2009, 10:15:20 AM »
is it just me
or do these tests seem to be done with a synthetic oil
(personally i use regular)
Re: Lucas
« Reply #11 on: February 06, 2009, 10:59:44 AM »
I use conventional oil too. Used it in my Celica every 6000ish miles 'till I sold it a couple years ago with....
264,000 miles on it!!! And, the compression was still within spec!!! The car ran great, but figured it was time to move on (was tired of not having A/C). And get this - I used SuperTech from Wal-Mart. It gets good reviews on oil analysis. But, I recently noticed the price jumped from $7ish a bottle to $10 WTF??? That puts it in the same price range as Valvoline, Quaker State, Mobile 1 and other 'brand names' (though, I'm sure SuperTech is a 'brand name' re-labeled). So, I'm going to re-research these oils and see how the Used Oil Analysis (UOA on bobistheoilguy.com) comes out on them.
« Last Edit: February 06, 2009, 11:03:25 AM by Jeremiah »
Offline Carnage
  • 2453
Re: Lucas
« Reply #12 on: February 06, 2009, 07:21:06 PM »
Next time I change oil (in 1k miles or so) I'll probably use my Slick50 additive.  Its sitting there so midas well put it to use.  I'll use regular oil and most likely the FRAM filter thats sitting there too.
I change my oil every 3-5k.  (once or twice a year)
*shrugs*
Then again.  I cant run compression tests so what I dont know cant kill me.   :angel:
Offline IanL
  • 466
Re: Lucas
« Reply #13 on: February 08, 2009, 01:55:56 AM »
The best thing to do with that Slick50 is throw it away.  It clogs filters, does no good and is known to increase wear.
http://skepdic.com/slick50.html
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Lucas
« Reply #14 on: February 08, 2009, 08:36:20 AM »
Except he's also running a Tornado air intake insert and a +50 horsepower chip with his electric supercharger.  If he quits using Slick50 now, he'll give up 79.2% of his gains.
XL-7 front coils
