transfer case e-brake set up
  • 1522 Views
« on: February 02, 2009, 10:44:23 AM »
Just wandering if anyone has installed one before? How bad was the install
Offline cj
  • 1276
  • I drive a really big ATV
Re: transfer case e-brake set up
« Reply #1 on: February 02, 2009, 01:40:47 PM »
If you mean the Spidertrax one then I'm currently doing that on my SJ410 but I'm also doing it with the Trail Tough disconnect so there is a little fabbing needed but the straight e-brake install is pretty easy.
« Reply #2 on: February 02, 2009, 05:54:14 PM »
I've only worked on the Drum brake version for the SJ-410, it's pretty easy.  You just put on 4 bolts instead of the flange.  That reminds me, I need to adjust it again...
