Screaching Squeeling Noisy Belts at Start up or going Slow (need some advise)
  • 23 Replies
  • 4839 Views
Offline dingus
  • 107
Love my New 1997 LSI Tracker but EVERYTIME i start her Up the Belts or Belt Makes a God Aufull Screaching noise.
It stops abit when i put the Tracker in Reverse. but is still there till i reve it up as i drive Away the sound Stops Dead!
Now its Got Power stearing so it could be that belt or the ALT belt i checked they seem set up tight enough.
It does this whenever i stop at a Stop sign ect or go to the Store When im slowed down.
I tryed rubbing Soap on the Belts didnt help  :laugh: Ya well anything was worth a try its God aufull noisy.
So is it Belts or a Pully or What  ??? Im stumped.
Should i spray oil on the Belt pullys?
Offline chevycotton77
  • 88
  • lets go whheellin
my 96 did the same thing. i thought it was the pullys but i went ahead and changed the belts and it hasnt done it ever since.
96 2D Tracker stock, 30" BFG MTs, 6inch calmini combo soon :)
Offline zukizuki07
  • 251
belts, and no belt dressing doesnt work hahaha spend a few bucks and replace them. should take care of it
96 2 Door Tracker
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
belts, I can make mine stop squealing by turning off the fan
Mean Green Wheeling Machine
Offline ROSS
  • 1412
also make sure they are the right size . not just length also width
Offline dingus
  • 107
OK so you guys all Agree its the Belts eh ?
Both or just one ?
Guess change em both while im at it eh.
Man thats fricken Horible noise!
Any Tricks to belt changeing?
Theres not exactly alota room in there for my club like hands eh.
  • 88
  • lets go whheellin
yeah its a pretty tight fit, shouldnt take more than 30 min though
Offline RACER X
  • 383
  • zuki or die!
i had same prob i thought my alt was bad i took it in the mech changed the belt wich was new using a shorter one (half inch) also put it on real tight with a pry bar big one it worked like a charm
98 kick
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
'course, he just took 3-years off your alternator's bearings..
XL-7 front coils
1.5" rear coil spacers
Offline zukizuki07
  • 251
+1 wouldnt go back to a mechanic that used a pry bar to apply a belt, it should take zero effort to install, thats why they make an adjustment bracket for an alternator..... put it on..... then force it tight then tighten down the adjustment. using the correct belt.
96 2 Door Tracker
Offline RACER X
  • 383
  • zuki or die!
ok so the Suzuki mech is wrong and you two dips are right my bad atleast my $hit dont squeak!!!
98 kick
I always use a pry bar, I find it the easiest way to hold the alternator/PS pump out when tightening the bolts. I just don't push on it hard and I check the belt free play afterwards.
Offline zukizuki07
  • 251
using a pry bar to hold the alternator is one thing, the way i read that post he used a smaller belt so had to use the pry bar to get it past the pulley?
96 2 Door Tracker
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Exactly.  What I'm saying is that nothing will kill an alternator better than overtightening the belt.  Well, except for submergence in mud or water.  And hammers.  And .50 caliber rounds.
It sounded in his description that the mechanic tightened the hell out of that belt.
Said Suzuki mech fixed your symptom just fine.  Happy customer!  Plus, hey, another few bucks when you need the new alternator put on.  Win-win!
XL-7 front coils
Offline dingus
  • 107
LOL  ;D well i have used a Pry bar to on my Big Ford Truck to tighen the Belt on my Alt.
It sounds bad but its just a Lever to get the Alt to come over nice and Easy also gives you a free hand to use a wrench on the Ajustment nut to tighten it up.
Prybar or a piece of Pipe works to but a pry bar is the Right shape to get in there.
I was told by a Local Mechanic to Tighten the Belts. My belts look new and seem fairly tight.
I will buy a new Set replace em and keep theses ones as Spares tho.
Haveing Spare Belts under the seat aint a Bad thing to have i figger.
