96 Kick with code PO-740 ?
  • 1859 Views
Offline ToyYoda
  • 226
« on: February 11, 2009, 10:09:00 AM »
 I talked a friend of mine into buying a Suzuki SideKick after his Jeep was stolen. He like's the veh. & want's to build it up but 1st needs to get it through smog. It has a "check engine" lamp on. I put my scanner tool on it & got a code (PO740)? We checked our "Chiltons" manual & found the codes stop at PO715 ! Working with Toyotas i have seen Automatic Trans. codes to be high #s and not on the code list. Has anyone seen/know what this 740 lamp code is? Know the veh.is a Fed. model 2dr. Kick. 4X with automatic trans., 1600cc/16 valve & built in Canada. Thanx
Offline ranger88den
  • 279
Re: 96 Kick with code PO-740 ?
« Reply #1 on: February 11, 2009, 10:38:52 AM »
Did a search for "OBD II codes"
P0740 Torque Converter Clutch Circuit Malfunction
Offline ToyYoda
  • 226
« Reply #2 on: February 12, 2009, 09:44:20 AM »
Great ! I thought it was a trans code but no info in my manual. I will look into this now. Thanx for the input. Jim
