How hard is it to remove the input shaft ?
  • 1733 Views
Offline RazBarlow
  • 156
  • It's Barney !
« on: February 17, 2009, 03:59:47 PM »
I was wondering how hard of a job it is to remove the input shaft on a 5 speed transmission out of a 90' sidekick transmission? It shows a little wear on the shaft where the pilot bearing runs. I will either build up the worn spot and machine it back on the surface grinder or I will turn it on the lathe. or I will buy a new one if I have to.
just wondering how much of a job it is.
Thanks,
Raz
Re: How hard is it to remove the input shaft ?
« Reply #1 on: February 17, 2009, 09:17:00 PM »
I don't think it's worth your effort, get a new bearing and call it good, otherwise, you have to take the
whole trans apart to get the shaft out
Good Luck
Offline Amilla
  • 1076
« Reply #2 on: February 18, 2009, 06:47:36 AM »
I haven't taken apart a trackick transmission before, but i have have had a sami tranny apart.  I had the same problem you are having, my input shaft was pretty worn out.
I just had to pull the tranny then split it in half, a couple snap rings later and i had the input shaft out.
Amilla
