lockers
  • 2397 Views
Offline Nicksidekickin
  • 104
lockers
« on: February 20, 2009, 01:09:53 PM »
I need some info. What is the best lockers for the best price for front and rear. I cant afford arbs, and with the front do they make a full spool since i have locking hubs i could use one on my everyday driver. Any input will be used. Oh its for my 96 sidekick.
1.5 coil spacers front and rear
custom rear bumper
windshield post lights
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
Re: lockers
« Reply #1 on: February 20, 2009, 06:20:00 PM »
Lockright in the rear, and the Lockright carrier from Trail Tough/Low Range Off-Road in the front.  :)
I would recommend against putting a spool in the front.
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
Re: lockers
« Reply #2 on: February 20, 2009, 07:44:32 PM »
Ditto on that, but try to put a steel diff in the front. That's what I did and when it warms up, a spool goes in the rear. Brent at Trail Tough will set you up!
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
  • 104
Re: lockers
« Reply #3 on: February 20, 2009, 08:42:20 PM »
yeah i've been checking out trail tough i like there stuff and low range is awesome to buy from
custom rear bumper
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: lockers
« Reply #4 on: February 21, 2009, 07:18:33 AM »
yep, no spool in front its to hard on it when turning you will blow a shaft.  Put on in the rear though, I like them better than lockers.. 2 years running on my rig now.
Offline RazBarlow
  • 156
  • It's Barney !
Re: lockers
« Reply #5 on: February 21, 2009, 07:26:15 AM »
But,
How does a spool perform  in the back on a daily driver ? How does it effect turning ? Is it hard on the rear end ?
What is a good locker and the best economical place to get one ?
Thanks,
Raz
Re: lockers
« Reply #6 on: February 21, 2009, 09:47:27 AM »
The spool is a little harder on the rear end, you mainly notice it when driving in parking lots.  Depending on your tires you will hear chirping as you drive around corners.
Just about everyone sells the Lock Right around the seam price, 235 from Low Range, http://www.lowrangeoffroad.com/kickaxles.htm
If your going to run a lockright in the front without switching to a steel front diff you have to get new carrier, also at Low Range.  Trail Tough sells them as well.
