what year is strongest samurai t-case?
  • 3102 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: February 22, 2009, 07:03:40 PM »
need a t-case for a project, thinking samurai is the way to go.  would it hold up to 100 hp and 6:1 granny low in a 4000 pound vehicle on 36s?
I heard there is a lot of differences in gears, is there any info on what years had what gears?
Offline Merlin93
Re: what year is strongest samurai t-case?
« Reply #1 on: February 22, 2009, 11:48:22 PM »
All years. Hi-range: 1.409:1; Lo-range: 2.268:1 .  All other ratios are aftermarket gears.
Visit the various Suzuki/Samurai specialist vendors to see who sells which gears. Gary Munck at Petroworks has done some analysis and claims his 4.89:1 low-range gearset is the optimum ratio for strength and longevity.  It's the only one PW sells.
T-case mounting appears to be the weakest point. This is a very common topic of discussion.  Much more information is available by searching.
« Last Edit: February 25, 2009, 08:42:30 AM by Merlin93 »
Offline locjaw
  • 2045
  • 22
« Reply #2 on: February 23, 2009, 12:24:36 PM »
i see absolutly no problem with that combo, theres people out there that have put v8's in front of a sammy t-case. the only problem your gonna have is if your gonna use the sammy axles, they wont hold up to a 36" tire.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #3 on: February 23, 2009, 12:51:56 PM »
Yep all years are the same really.
« Reply #4 on: February 23, 2009, 05:45:58 PM »
Front output shaft got re-designed by Suzuki at some point. Older = weaker. Not sure what year the split was. Find a way to keep the t-case from wriggling around, and it'll live with 100HP on big tires.
« Reply #5 on: February 23, 2009, 09:19:54 PM »
I have heard both 90 and 93 for the updated front output.  But I haven't had a reason to tear my 91 or 92 tcase apart to see which it is.
Offline Amilla
  • 1076
« Reply #6 on: February 23, 2009, 09:31:13 PM »
You can always upgrade to the bigger front out put shaft.
I have also seen some home brew ideas of how to improve the older version, by simply putting a washer behind the shaft.
Amilla
Offline mcbrat
  • 19
« Reply #7 on: February 24, 2009, 08:10:22 PM »
while i'm not that heavy, I'm counting on it holding up to about 110 hp with 35s on a approx 3100 lb rig...
Samurai t-case, surrounded by a Subaru Brat.  linked with Toyota axles and 35" tires.
