Biggest tire for 99 chevy tracker soft top 4X4
  • 9 Replies
  • 7565 Views
Offline rpa740tracker
  • 9
« on: February 23, 2009, 12:03:45 AM »
I was wondering does anybody know the biggest tire I could put on a stock 99 tracker soft top 1.6 4X4.I saw a stock ZR2 soft top with 235 75 15 tires on it but I do not know if there is a difference in clearance on a regular and a ZR2 tracker,The owner of the ZR2 told me he made no modification to his and it does not rub or cause any problems.
Any help would be appreciated,
Randy  :)
Offline TopHeavy96
  • 488
Re: Biggest tire for 99 chevy tracker soft top 4X4
« Reply #1 on: February 23, 2009, 04:41:37 AM »
I recommend you get jeff's spacer lift, it's only about as expensive as an extra tire. Then you can fit about 29-30"s ;)  I think 235s will fit stock though.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #2 on: February 23, 2009, 06:41:49 AM »
I agree with topheavy96.  The only differerence I am aware of in the fender area between base models and the ZR2 is the ZR2 comes with the fender molding, 6 inch rims versus 5.5 inch rims, and 215 tires versus 205s.  235/75/15s should fit ZR2s with no significant problem  I saw a 2-door ZR2 with 225/75/15s on it and there was plenty of clearance.  I put 235/70/15s and a set of 235/75/15s on two regular Trackers (not ZR2s) before I lifted them and the only rub I had was on full lock-up turning.  They are both now lifted and I still get some rubbing on full lock up.  But I rarely turn that hard.  Rarely.  I'm sure I could pop a set of 30/9.50/15s on without too much more rubbing, I just want to step up to more differential gear before I do... and also get the full wear out of the tires I'm currently running first.
« Last Edit: February 23, 2009, 07:33:31 AM by nprecon »
  • 9
« Reply #3 on: February 23, 2009, 08:39:27 AM »
What is Jeffs spacer lift?
« Reply #4 on: February 23, 2009, 08:55:57 AM »
A good inexpensive way to mount bigger tires.
http://www.zukiworld.com/forum/index.php?topic=24199.0
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline jeff1997
  • 1228
  • 27
« Reply #5 on: February 23, 2009, 08:57:47 AM »
Hi it's Jeff.  ;D My spacer lift is 1.5" coil and strut spacers for the front and 2" coil spacers for the rear. This gives you a full 2" of suspension lift all around and will not affect the drive or ride. It is easy to install and pretty cheap. The 99 and newer version costs $155 total shipped to you in the US or $170 to Canada. The only thing you will need to add are longer rear shocks. Monroe-matic #32260 fits great.
3" Masterkit1 body lift
Custom strut spacers
  • 9
« Reply #6 on: February 24, 2009, 09:25:21 PM »
With yhe space lift do I have to modify any of the lines or cables Etc, on my tracker to use it?
Thanks
Randy
  • 9
« Reply #7 on: February 24, 2009, 09:26:36 PM »
Thanks for the info
Offline TopHeavy96
  • 488
« Reply #8 on: February 25, 2009, 04:29:28 AM »
I didn't have to modify the brake lines or hoses, but I did extend the rear axle vent hose,  and moved the rubber mounts for the E-brake cables.
Offline bzzr2
  • 1011
« Reply #9 on: February 26, 2009, 07:19:35 AM »
i have not modified lines yet.. my rear lines with approx 3inches of susp and 2inch bl, however i think i will have to look at loosening up mounting points for the lines when adding long shocks this year, things are maxed out.
09 taco reg cab short box 4x4
