Manual Hubs not engaging
  • 9 Replies
  • 3029 Views
Offline Jarrodl
  • 40
  • She thinks my TRACKERS sexy!
« on: August 24, 2004, 07:24:04 AM »
I have a 90 tracker and my drivers side hub sometimes doesn't engage. The switch turns fine, it just doesn't lock. I have pecked on it with a wrench and made it engage. It is a factory manual hub. Does it need cleaning? could there be something else wrong?
96 Tracker 4x4 Automatic 2dr Soft Top
Offline trackermad
  • 150
Re: Manual Hubs not engaging
« Reply #1 on: August 24, 2004, 07:27:40 AM »
Id start with a good cleaning..... Its pretty easy to do.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
« Reply #2 on: August 24, 2004, 07:34:33 AM »
Yea, just clean and re-grease and it should work fine.
Offline Jarrodl
  • 40
« Reply #3 on: August 24, 2004, 07:58:13 AM »
What has to be taken off to clean them? I guess the wheel has to be taken off, but what else? Do the allen head bolts around the hub need to be removed? Does the rotor and wheel bearing have to come off?
Offline 1bigtracker
  • 3409
« Reply #4 on: August 24, 2004, 08:12:32 AM »
their are like 6 12MM?? bolts around the base of the hub.  take those off and take the hub off the CV.  then CAREFULLY disassemble the hub, clean all the rust and what not out of it, gease and reassemble.
stu
Offline trackermad
  • 150
« Reply #5 on: August 24, 2004, 10:15:27 AM »
Last time I did it I didnt even take the wheel off...
Offline keith
  • 1176
« Reply #6 on: August 24, 2004, 02:12:59 PM »
How can you tell it is not engaging?
Offline szabotage
  • 114
  • snaggletooth
« Reply #7 on: August 24, 2004, 02:40:44 PM »
you don't even have to take the hub off to clean the hub just the switch cap and all the internals'll pop out.
personally I like to give it a bath in the solvent tank so I take em off completely
Offline Jarrodl
  • 40
« Reply #8 on: August 25, 2004, 04:48:39 AM »
I got stuck.  Actually, I got out and looked at my front axles. The one on the passenger side wasn't turning, and the one on the drivers side was turning and the wheel was not. I pecked it with a wrench and when it engaged, I got out of the mud no problem.
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #9 on: August 28, 2004, 11:25:22 PM »
most probably, the internals are dirty, or rusty.
same thing happened to mine.
i didnt take the wheel off, i took the switch out, with internals, and then i took the outer hub off. cleaned all in solvent, (i used diesel), it was mainly rust that stop the internals sliding. make sure that the spring is in place, (connected to the spline ring, and the switch)
my spring also come off the spline ring, this meant that when it engaged, it would disengage.
make sure to grease it up properly, but not to pack it full of grease, as it wont work then. also, some people cut out a gasket/seal when replacing, but i found that was a waste of time, as any type of water crossing/mud will enter the hub through the switch.
this is something i do when i get my vitara serviced. engine oil, air filter, etc.
its straight forward. just do it.
