Will my rear springs fall out?
  • 3374 Views
Offline zo6gun
  • 43
« on: March 07, 2009, 11:18:42 AM »
Hey Everyone 8)........Just one question. Recently I installed a OME kit with spacers for a total of 3" lift. When the rear suspension is at full articulation the Rear springs are loose with about a 2" space is this normal. ??? I contacted Rockey Road where I Got the kit and they said Its OK not to worry.Has anyone had the same issue. I don't think the springs would fall out but need some advice...... :police:.ZO6GUN
Offline nevadasmith
  • 112
  • hey, wait wait I got a new idea!
Re: Will my rear springs fall out?
« Reply #1 on: March 07, 2009, 12:27:07 PM »
It depnd on the shocks, if you use Ome or doestech shocks for a three inch lift you will be fine if you use f150 or LTD shocks then yes they will fall out........
92 hardtop removable + swampers + 2.5" lift+ locker+ onboard air
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: March 07, 2009, 01:36:18 PM »
My springs fall out with my 4 inch suspension lift.  Limit straps will stop ;)
Offline zo6gun
  • 43
« Reply #3 on: March 08, 2009, 12:34:04 PM »
Hey John.....I think I will go with the Limit straps. Should I go from the top spring mount to the axle or from the shock mounts to the shock axle mount? ??? The shocks I used are the F150 because they gave a much better ride compaired to the Rocky Road shocks. :P Thanks for any help you can give me...... :police:ZO6gun
« Reply #4 on: March 08, 2009, 02:16:58 PM »
If you fit some sort of dislocation cones then you can keep the springs in place without loosing articulation
Offline zo6gun
  • 43
« Reply #5 on: March 08, 2009, 09:23:19 PM »
Hey Rhinoman.....What in the heck are dislocation cones? ??? How about some pictures..Thanks a bunch for the Info.......ZO6-Gun (go fast or go home)  >:D
Offline zukizuki07
  • 251
« Reply #6 on: March 08, 2009, 10:20:32 PM »
your spring would be outside a cone shape like this.
96 2 Door Tracker
Offline zo6gun
  • 43
« Reply #7 on: March 09, 2009, 09:01:03 AM »
Hey 07.......Got it, thanks a bunch........ZO6=Gun
