Kick T-case options
  • 1535 Views
Kick T-case options
« on: March 10, 2009, 01:07:30 PM »
I've got some yota axles with 35" tires, and 4.88 diff gears, and sami t-case. This should be a perfect combo (rev slightly higher to make up for rotational mass). I was originally going to buy the Rock 4x Fab adapter to make a doubler, but money's starting to get tight. I just got a 2-door with a 2wd 5-speed (I wanted an auto, but... again $$$). It's my understanding the sami t-case can be mated to the 2wd trans somehow? Is this a divorced, or mated setup? Anyone have details they can share?
Re: Kick T-case options
« Reply #1 on: March 10, 2009, 03:27:07 PM »
It will be a divorced setup, you will need the original jack shaft off of the Samurai.  It should have the same splines as the Tracker 2wd transmission.
Offline zuk4life
  • 16
« Reply #2 on: March 10, 2009, 09:28:38 PM »
The 2wd tracker 5spd is weak. Id get 2wd 3spd auto, or 4x4 3spd trans minus t-case with trail tough adapter. Even the sammi 5spd trans is better and has a good ratio. Might also want some kind of t-case gears. What year's the trackick...16v or 8..? Oh ya sami trans is also shorter(better d-line angels).           ps build what you got?
« Reply #3 on: March 11, 2009, 02:33:19 PM »
I'm looking in TT's site, and don't see any trans adaptors  ??? http://www.trailtough.com/index.php?option=com_virtuemart&orderby=product_list&page=shop.browse&category_id=18&Itemid=53
It's a 16V. I have a 16V with a 4-speed auto and everything else that goes with it. I'd much prefer that over a 3-speed auto. With 4.88, 35" tires and the Samurai T-case, it will already be over-revving a few % (to make up for rotational weight), so I don't want to put in any lower t-case gears. Even 4:1 gears would put me into 41.5" tires :o. When I can afford it, I'll get the doubler and have enough low-range.
More and more I'm wondering if I should sell the two 1.6L 16V engines I have and get my hands on a 2.0L  with an auto ??? Swap doesn't look too hard (I know, famous last words): http://members.cox.net/aftermarket4x4/current_proj.html
