How does your hardtop mount ?
  • 19 Replies
  • 5646 Views
Offline RazBarlow
  • 156
  • It's Barney !
« on: March 12, 2009, 02:31:48 PM »
My hardtop on my 04' track mounts with only two bolts on each side up in the front corner. I am thinking maybe there should be a couple more on the back corners.
Thanks,
Raz
Offline mike5721947
  • 545
Re: How does your hardtop mount ?
« Reply #1 on: March 12, 2009, 04:39:52 PM »
mine has 2 clips on the inside on the very back. locks it down pretty good.
31" kumhos 3inchs of lift.
Offline skitime
  • 302
« Reply #2 on: March 12, 2009, 05:06:45 PM »
Is that on the outside of the truck?  That does not look original. That would make it easy to steal.  It appears those bolts were added. My hardtop has two plates mounted on the inside at that location and two plates mounted at the inside rear.  Those plates then hold the hardtop with large 3 inch round knobs that screw into theaded holes in the hardtop.
« Last Edit: March 12, 2009, 05:18:31 PM by skitime »
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
« Reply #3 on: March 12, 2009, 05:23:32 PM »
I agree with skitime.
It looks like someone added a couple of bolts.
The Removeable Hard Tops that I've had have looked similar to skitime's pictures. Other than that, they kinda fit snug in the channel around the rear and targa bar. Then, once you shut the tailgate, that secures them too.
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #4 on: March 13, 2009, 04:24:26 AM »
The previous owner has half a$$ed everything on this tracker so I do not doubt that it is not mounted correctly . Ski, Do you have any brighter pics you could get me and how the knobs are mounted to the hardtop ?
I will need to make me some brackets or buy some used ones.
I didn't think this was right , as it would be difficult to remove the hardtop quickly when you wanted to.
Thanks so Much !
Raz
Offline bzzr2
  • 1011
« Reply #5 on: March 13, 2009, 09:21:03 AM »
i just bought a used hard top and only have it on with the front screws, the back mounts won't go on cause i've got some terribly rusted bolts that i can't remove cause i need an extension for my drill to try and drill out the bolts and put some new ones in that can hold the block that the back clips to..  i'll take a few pics.. mines an '03.
09 taco reg cab short box 4x4
Offline skitime
  • 302
« Reply #6 on: March 13, 2009, 02:07:16 PM »
Raz
Sorry I ran out last night to get those pics for you.  Here I lightened them up and took 2 more for you.  The knobs screw into a captured nut molded into the hardtop.
Offline mike5721947
  • 545
« Reply #7 on: March 13, 2009, 02:30:10 PM »
man... mine just seems way simpler.... just tilt up to slide the front c channel in and drop the back down to the body, then flip up the clips and lock it down...
pro top if anyone is wondering.
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #8 on: March 13, 2009, 02:40:39 PM »
Have any mounting pics of the clips ? And how your system mounts ?
Thanks,
Raz
Offline mike5721947
  • 545
« Reply #9 on: March 13, 2009, 03:15:01 PM »
my mistaske mfg: proform products corp model: protop made in 1993
leaves the inside nice and clean looking...
unforunitly im looking for the front section for it right now (mines broken...) :'(
Offline blacktrack99
  • 254
« Reply #10 on: March 13, 2009, 06:38:28 PM »
Who made that hard top for your '04?  The one for my '99 is from rally Tops.  It does only have two attachment points [on the inside where the soft top mounting brackets used to be- bottom, center].  The original plastic trim was removed and replaced w/ weather stripping for a nice seal.  It's done everything from washboards to daily commutes, freeway speeds, and some pretty rough wheeling without issue for a few years now.  I really only take it off for a good four-wheeling excursion when the weather's perfect.
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #11 on: March 14, 2009, 02:21:08 AM »
I just had to look at my original post . I fat fingered the year, it is a 94' not a 04' .
Thanks,
Raz
« Reply #12 on: March 14, 2009, 04:23:49 AM »
my rear section of top is held down by 4 small locking clips that cinch down the top when locked, when you lock them theres a hook at the end of one side that goes into an eyelet and pulls the top to the body, it works well. if i can get pics while im workin on her today i will. as far as my front section, a ratchet strap holds it down, other wise the front clips allow it to take flight.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #13 on: March 14, 2009, 06:24:42 AM »
This is how mine mounts too. I got the hardtop without the mounts, just went to a local salvage yard and found a set.
« Reply #14 on: March 14, 2009, 09:11:07 AM »
We have an old Besttop Hard Top, it uses the screw in ends and the mounts that go in the Soft Top points.
