tracker on samurai frame?
  • 7 Replies
  • 4177 Views
Offline machz
  • 24
« on: March 23, 2009, 03:32:52 PM »
looking to put a tracker body on a sammy frame ! anybody dit that? any pics? right now ive got 2inch susp and 3 inch body lift and its still not enough !
Online ebewley
  • 6602
  • 69
Re: tracker on samurai frame?
« Reply #1 on: March 23, 2009, 04:05:48 PM »
That picture you've showed us there has no body lift! Is is a current picture?
SO, how large do you want to go? The tracker frames are just as ready to take modfications as the Samurai. Are you looking to go Solid axle up front like a Samurai? That too can be done without changing frames. The jist of this bit is that switching frames would be a pain in the bottom and wouldn't gain you anything.
Offline machz
  • 24
« Reply #2 on: March 23, 2009, 04:12:46 PM »
no didnt have my body lift on that pic .. more pics to come... i'm looking for the easies way to have a front strait axel  .. but id like to use the one of a samurai have one already.. ive got a complete samurai frame with power train so i tought it would be easy to put my tracker body on that frame has well as my tracker engine ..lol
Offline Lindenmooch
  • 560
« Reply #3 on: March 23, 2009, 05:01:16 PM »
Sounds complicated.
If I were you...I'd try to sell all your samurai stuff to one of these zukiworld whackos....and then do a SAS(solid axle swap) with all the monies.   Or...a multi-link/swing arm rear end setup...with a fancy coilover lift and bigger control arms in the front.   That would be cool.
Offline norcalwreckchaser
  • 128
    • www.norcalwreckchasers.ning.com
« Reply #4 on: March 23, 2009, 06:57:11 PM »
Sounds complicated.
+1
86' Samurai, 5" spua lift, rear missing links, 4.57 gears, 4 to 1 Transfer Case, Lockrights F/R, ARB Front bumper, Doug Thorley Header, Rock Rails, GM alt. swap and other Misc. goodies.
Sold 7/10 :(
Offline mike5721947
  • 545
« Reply #5 on: March 23, 2009, 07:05:04 PM »
either swap the front suspension from the sammy to the kick frame and install the kick front third (to have the proper gear ratio) then sell off the rest of the sammy stuff.
or just sell the sammy stuff and get some yota axles and do it that way...
would be more work to swap the frames then it is to do the solid axle swap on the tracker frame.
31" kumhos 3inchs of lift.
Offline Bryce132
  • 117
« Reply #6 on: March 24, 2009, 04:01:01 AM »
What kind of tires are those? Any good?
You should stuff some 33's under there and beef up some drivtrain...
Bryce
Offline machz
  • 24
« Reply #7 on: March 24, 2009, 11:05:06 AM »
there just 31 inch remoulds there aint wort shit.. running 31 11.50 super swampers right now ... i could run 33 i have to drive 60 milles every day to get to work...lol
