question about fuel pumps
mcs
158
I love YaBB 1G - SP1!
March 24, 2009, 09:45:00 PM »
I have no know idea if this will work but can a fuel pump from a trackick go into a fuel injected sami.?
If not does anyone know of a cheaper fuel pump for a sami then the $200.00 one from autozone.
mrfuelish
2862
13
you must have a perception problem.
Re: question about fuel pumps
March 24, 2009, 10:48:56 PM »
try a 88-92 toyota corolla, 90-93 honda accord, #kep-403, 195130-2250.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
AZ148
13
March 26, 2009, 05:20:08 AM »
I'm running a carter pump on mine. $140 from Summitt racing.
mcs
158
Reply #3 on:
March 26, 2009, 02:24:03 PM »
AZ148, Did it drop right in and how has it worked?
96Kicker
1043
http://www.zukiworld.com/forum/gallery/3710_25_10_
Reply #4 on:
March 26, 2009, 08:37:38 PM »
Have you tried the junk yards yet. When I did my 1.616V swap on my samurai I paid 40 bucks for a complete tank/with pump from a tracker.
<a href="
http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view¤t=Zuktahgreenblur.jpg
" target="_blank"><img src="
http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg
" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
AZ148
13
Reply #5 on:
March 27, 2009, 12:02:03 AM »
MCS.. I have a 1.616v in my Sammy. I installed a frame mounted fuel pump. You said your is fuel injected.. right?. Just make sure you use a pump with the appropriate amount of PSI.The part # through Summit was CRT-P5000. If you go this route make sure you use a fuel filter that is designed for fuel injection. I have one of the metal in line filters between the tank and pump. I made the mistake of using a stock filter for a 1.3 and it came apart on me. Also check your return line in the area above the passenger-side rear tire. If you converted motors there is an in line check valve that needs to be removed. Hope this helps.. sorry about the delay in writting back.. Good Luck
88samuraion31s
9
Reply #6 on:
March 28, 2009, 06:37:40 PM »
why does that check valve have to be removed?
