transfer case probleme
  • 4 Replies
  • 1882 Views
Offline machz
  • 24
« on: April 06, 2009, 06:05:10 PM »
ive got some play in my transfer case back and forth .. is it gears or a chain?
Offline ROSS
  • 1412
Re: transfer case probleme
« Reply #1 on: April 06, 2009, 07:09:34 PM »
all gears no chain.  check the flanges to make sure there tight .  don't know where a lot of play good be
« Reply #2 on: April 07, 2009, 04:20:30 PM »
Wouldn't that depend on the vehicle?
Looking at the FSM for my GV it says ...
The aluminum transfer case directly connected to the back of the transmission contains the input gear, countershaft & gear, output rear shaft, output low gear and output front shaft (for front drive) connected by way of the hyvo-chain.
Offline Hillbillydave
  • 213
« Reply #3 on: April 07, 2009, 07:33:03 PM »
Trackick's have a chain as well, but this would not cause play in the shifter, if that is where the play is. Shifter play can be fixed by installing a new shifter sheet, sold buy many of the sponsers of this site.
'89 sidekick 1.3L 3" blue suspension parts, custom strut extensions 31x10.5 Mud Trac's on 10" rims rear fenders trimmed, lincoln locked rear, Rochester Carb on custom adapter
93 Sammy project, SPOA with 34's, 5.12's, welded, in the works
Offline idaholwb
  • 772
« Reply #4 on: April 07, 2009, 10:17:12 PM »
Trackicks have a chain and Samis have just gears.
97 Sport
265/70-16s
2" lift
2.0 swap
