88 zuk clutch
  • 2072 Views
Offline 88zuk
88 zuk clutch
« on: April 14, 2009, 12:23:37 PM »
i just bought an 88 samurai, and i not sure what exactley is wrong with it , when i put a jack underneath the samuraiand lift the rear tires i can make the tires bareley spin whith the gas mashed to the floor, it seems to go into every gear but it will idell in gear, is my clutch bad?
Offline 88samuraion31s
  • 9
Re: 88 zuk clutch
« Reply #1 on: April 14, 2009, 06:04:34 PM »
It could be.. It dont make any noises or anything?
Offline 88zuk
Re: 88 zuk clutch
« Reply #2 on: April 14, 2009, 06:30:59 PM »
no theres no noise it feel slike the  clutch is still there when you press the pedal
Offline norcalwreckchaser
  • 128
Re: 88 zuk clutch
« Reply #3 on: April 14, 2009, 07:25:26 PM »
Check your cable adjustment on the Trans and at the pedal, did this just happen or are you new to the vehicle?
Norcal
Sold 7/10 :(
Offline 88zuk
Re: 88 zuk clutch
« Reply #4 on: April 14, 2009, 07:40:25 PM »
i jut bought the samurai it drove around good i may have put 5 mile on it and then one day i went to move it and it was like this
  • 128
Re: 88 zuk clutch
« Reply #5 on: April 14, 2009, 09:47:08 PM »
I would go with checking the clutch cable first, I can't think of any reason why your clutch would go bad by just sitting a while.
Norcal
Sold 7/10 :(
