Trail Tough springs too soft 4 some.
  • 3130 Views
Offline ToyYoda
  • 226
« on: April 14, 2009, 06:18:57 PM »
Have a X90/Sidekick & installed Trail Toughs link kit/Toyota axle conv. kit. After running the veh. for over a yr. now & added aprox. 200 lbs. of metal (bumpers, sliders, spair tire carrier & cage), the veh. bottoms out everywhere. I never installed the supplied shocks with the kit but used better res. Fox's on rear & res. Bilstein's front. They are gas charged & should help but driving down a dirt road & running over a rock or ditch more than 3" bottoms out my rig hard. Ok, the kit is sold as "rock crawler" in design but in my world it requires driving sometimes 5-10 miles off road & most off the crew wants to run 30-40 mph on these dirt roads. I have to drop down to 15 every time I see a 3'' or greater hit. DON'T get me wrong about the kit. It works awesome crawling but seriously lacks as a cross country rig. Yes i spoke with Brent but he said "no" to offering a (heavy duty) spring option. Iv'e talked briefly with a guy selling his 4dr Kick on San Diego Craigs list with the same kit & he too had the problem with springs too being soft. He replaced them with better/stiffer spring but i never found out who made them. Now I know several people on ZukiWorld have this kit so hope/pray someone has done the research. Would like 50 lbs increase on each spring if poss. PLEASE HELP  :(
« Last Edit: April 15, 2009, 07:50:11 AM by ToyYoda »
Re: Trail Tough springs too soft 4 some.
« Reply #1 on: April 15, 2009, 03:39:03 AM »
Try Blue Coil springs, they make many different rates and lengths.
« Reply #2 on: April 15, 2009, 05:49:45 AM »
Contact Liberty Overland www.liberty-overland.com. I had the same suspension put in my new adventure vehicle and they tweaked the suspension to accommodate for the V-6 and extra weight of the cage, full size spare etc....  They can order you what you need.
Offline locjaw
  • 2045
  • 22
« Reply #3 on: April 15, 2009, 07:44:57 AM »
I also have the slayer kit on my vehicle(i actually have kit #1 which is a little different than the kits sold now)and i too have had Liberty Overland help rework my suspension. i have added solid bumpstops, reworked the rear shock mounts to accomodate bilstein rebuildible shocks, and changed the springrate. In my opinion the shocks and bumpstops are the best upgrade you can do to these things, however changing the springs is manditory also. Eric is awesome to work with and does top notch work. Give him a call and he'll hook you up!
Liberty Overlands phone # is....541-967-3255
Offline ToyYoda
  • 226
« Reply #4 on: April 15, 2009, 07:57:56 AM »
GREAT !  Where would I be without the group of Suzuki owners found on THIS site. I will talk with the spring manufacturers today!  ;D
« Reply #5 on: April 15, 2009, 01:42:15 PM »
How do you like those Bilsteins in the front?
Offline locjaw
  • 2045
  • 22
« Reply #6 on: April 15, 2009, 04:50:18 PM »
the shocks are the best money i have spent yet. rides like a freaking caddy now.
« Reply #7 on: April 15, 2009, 08:21:31 PM »
Do not listen to Jason, he is eevil!
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #8 on: April 18, 2009, 07:37:45 PM »
I had to go up in spring rate in the front. I think I am running a 255lb 14" coil and am planing on increasing that to about 16" coil same rate. The no uptravel on these trucks is undesirable for most of us who run these kits on various terrain. I think about 5-6" of up travel is just about perfect with some really good bumps stops. Liberty overland did my bump stops when my junk was up there getting the V6 installed. I need better shocks too.
