Front End Alignment Specs. O.K.?
  • 18 Replies
  • 12443 Views
Offline one mile
  • 174
« on: April 20, 2009, 10:06:15 AM »
O.K. I took my Samurai out for a spin for the first time after front end rebuild...new Drag Link ,Steering rod and Tie rod ends and it still seems to "Wander" around on the road.The steering box seems to be tight. I did a back yard alignment but I need to take it to a real shopI know. Are the stock specs. O.K. or is there a better set of specs for a stock height Samurai with 8 in. rims and 235/75/15 's on it?
"WORK SMART NOT HARD"
Offline scoutman73
  • 14
  • 1997 Suzuki Sidekick Sport , some mods.
    • Flickr, pics of my Sidekick Sport
Re: Front End Alignment Specs. O.K.?
« Reply #1 on: April 20, 2009, 11:20:45 AM »
If you have lift shackles in the front or lifted springs , then your caster angle could be off . Just use shims between the axle and leaf springs too correct the caster angle . hope that helps .
Suzuki Sidekick Sport 1997 1.8L auto 4dr.
ZOR winch bumper , Smittybuilt 8000lb winch
RRO rock sliders , 2" body lift, OME springs, struts, Jeff's spacers
Goodyear MTR's 245\75\16, 1.5" wheel spacers
Pics of my Suzuki Sidekick http://www.flickr.com/photos/20915236|removethispart|@N08/sets/72157614268325908/
Offline one mile
  • 174
« Reply #2 on: April 20, 2009, 01:51:07 PM »
Nope...Stock suspension......
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: April 20, 2009, 02:06:13 PM »
Possibly worn kingpin or wheel bearings, then.  Jack up each front wheel separately  and check for play - top to bottom and side to side.  There should be nearly zero play.  Bearings are pretty simple to find. If the vendors that advertise here don't have them (sometimes their sources dry up) Auto parts stores or bearing supply houses have them.  For more info on front kingpin and wheel bearing replacement, download the Samurai FSM at Ack's FAQ (the link is in my signature)  do a search for fsm.
BTW - "toe" is about the only thing that you can adjust.
Ack
Offline one mile
  • 174
« Reply #4 on: April 20, 2009, 03:35:23 PM »
Does anybody have a cross Ref. # for a steering dampener that will fit that is not so $$$$$ !
Offline one mile
  • 174
« Reply #5 on: April 20, 2009, 05:32:52 PM »
Got one on order.....Any input on what to tell shop on toe? Need to stop that "Wandering".
Offline fuzzy1
  • 350
« Reply #6 on: April 20, 2009, 07:00:51 PM »
Well, be sure to check the bearing play as Ack said before you even take it to an alignment shop. They woudl likely check anyways, but if they didn't & your bearings are out of spec no alignment will help. The good news is your sammys bearings are lots easier to get to, repack, retorque, &/or replace than trackicks are (sammy has no crush bearing). Another thought: your 8" rims may be a bit wide for 235's depending on the actual tire width, which varies some by maker. 235's work out to approx 9.2" wide tread. Maybe the sidewalls are spread too far? 8" is actually pretty wide for a 30x9.50... maybe they're causing the tire to 'reverse' crown? Just a thought...
Non Illegitimi Conterat
« Reply #7 on: April 21, 2009, 09:51:48 AM »
For the steering dampner the local shop should be able to find one pretty cheap.  My winch is mounted through where the stock stabilizer ran so I ended up using a Toyota one instead.  It's about 4" longer and had enough length to run to a new mount on the other side of the frame from the steering box.  It was only $20-30.
Offline one mile
  • 174
« Reply #8 on: April 21, 2009, 02:31:09 PM »
I have it taken care of ....Thanks for the help everyone!
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #9 on: April 21, 2009, 06:50:40 PM »
And?
XL-7 front coils
1.5" rear coil spacers
Offline fuzzy1
  • 350
« Reply #10 on: April 21, 2009, 07:01:30 PM »
And?
Hehe, yeah, wut did you do to fix it??  ???
Offline one mile
  • 174
« Reply #11 on: April 22, 2009, 09:55:48 AM »
Sorry about that......I took off my steering stabilizer to check to see how worn it was and it fell apart in my hands! I also ran my tire pressure up to 32 psi. The new Monro Magnum stabilizer was the trick. I now am so pleased on how it drives I have parked my other car an I drive this Baby every day!  By the way does anyone have a "source" for the new style King Pin Bearings for my '87 samurai that are not so $$$? Please let me knoww...O.K.?
« Reply #12 on: April 22, 2009, 10:06:22 AM »
You can get them at the auto store, or just pick up a full axle rebuild kit from Low Range Off-Road.
Offline idaholwb
  • 772
« Reply #13 on: April 22, 2009, 11:09:41 AM »
A knuckle rebuild kit has all the seals, felt wipers, wheel bearings and kingpin bearings to do both sides. Trailtough only wants $199 for the whole kit... It's your best bet.
 http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=111&category_id=14&option=com_virtuemart&Itemid=53
As far as the alignment specs are concerned, just have it set to stock, but rebuild the knuckles first. There is no cheaper way to get rid of 20 years worth of play...
And as far as your tire pressure is concerned... WHy do you have them inflated so hard? Trying to wear out the centers of your tires? Read the tire inflation decal on the door jamb, dash or kick panel and do what that recommends for pressure. It should only be like 20-23psi. The truck doesn't weigh very much. 32 is appropriate for like a 4-5,000 pound Jeep, not a 2,000 pound Suzuki.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline sammypro.com
  • 153
« Reply #14 on: April 22, 2009, 01:44:29 PM »
or for other options around $140
http://cgi.ebay.com/ebaymotors/Suzuki-Samurai-front-wheel-bearing-and-seal-kit-sammy_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a0Q7c293Q3a3Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem220262781256QQitemZ220262781256QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
