Tire size with Rock-Steady lift?
  • 2553 Views
Offline Turtle12
  • 17
« on: April 21, 2009, 05:17:30 PM »
I'm kind of new here, but I did do a search for this and didn't find what I wanted.  I am going with the Rock-Steady lift on my '02 Tracker.  Will 31x10.50's work without rubbing, or do I need to go with 30's?  Or will they still rub?  I'm going with 15x7 wheels if that helps.  Thanks in advance.
'02 Tracker
Rocksteady lift (minus the spacers)
Jeff's spacers
30x9.50x15 Kumhos
Offline blacktrack99
  • 254
Re: Tire size with Rock-Steady lift?
« Reply #1 on: April 21, 2009, 07:31:19 PM »
With or without the body lift? 30's w/out,  31's with.
Offline Turtle12
  • 17
« Reply #2 on: April 22, 2009, 05:49:04 AM »
Thanks for your response.  I'm going with the body lift, also.  With 3.75'' backspacing on a 7 inch wide wheel, how much tire will I have sticking out beyond the fender?
'02 Tracker
Jeff's spacers
30x9.50x15 Kumhos
Offline 2K1USGV
  • 218
« Reply #3 on: April 26, 2009, 02:21:52 PM »
Even with the body lift you'll have to trim your fenders to run 31's. Honestly, I would stick with 30"s, I've had tried anythingt from a 30 to a 32 on my GV and a 245/75/16 (30.5) was the best compromise with minimal rubbing. WOuld I do it again, I would stick with a 30" tire.
Offline Turtle12
  • 17
« Reply #4 on: April 30, 2009, 08:37:31 AM »
What about the backspacing?  Will 3.75'' work?  Or will I need spacers for those?
'02 Tracker
Jeff's spacers
30x9.50x15 Kumhos
