Trailer light wiring
  • 22 Replies
  • 8492 Views
« on: April 23, 2009, 10:24:17 AM »
Anyone here wire up the electric connector for a trailer & a tracker? Is there a plug hiding somewhere out back, or do I need to tap into the existing wiring harness for break / turn signal/ running lights?
Offline ranger88den
  • 279
Re: Trailer light wiring
« Reply #1 on: April 23, 2009, 11:48:54 AM »
Should be a plug behind the driver's side tail light housing (at least on my 95 Tracker).
« Reply #2 on: April 23, 2009, 12:12:07 PM »
If you dont have one (like my 89), behind the tail light is a good place to tap into the harness for a wireing kit.
« Last Edit: May 13, 2009, 06:00:07 AM by Zukipilot »
Offline Ira88888
  • 23
« Reply #3 on: May 12, 2009, 06:06:33 AM »
Okay, I'm going to be doing this this weekend, even though I don't have a trailer yet.
Ranger, I have a 95 2-door, so same deal? I can just plug in, with no special slicing? Or doesn't that depend on the HARNESS I get?
I figured I would buy a cheap trailer light set so I can test whatever I'm doing, but I don't know what the HELL I'm doing.
« Reply #4 on: May 12, 2009, 11:57:15 AM »
the plug is kinda back in there a ways, it is white square looking thing. LOL
Offline Ira88888
  • 23
« Reply #5 on: May 12, 2009, 04:37:05 PM »
Do I access it by removing the lens, or getting underneath and feeling around?
I got underneath this afternoon for a second--couldn't really look and get dirty because I was working--but I didn't see anything from that vantage point.
Offline mike5721947
  • 545
« Reply #6 on: May 12, 2009, 05:35:10 PM »
remove drivers taillight, reach in and above the wheel well its taped back on the main harness. remove the plug, wire in a converter (atleast i had to for my kick, as it has seperate turn signals) then route 4 flat connector out side of taillight opening and into trunk (can be seen sightly while looking at door gap when door is closed)  but allows the wire to be easily acessed you could drill the interior panel for it to run through, or fish it down to where the hitch its and mount it down there
i for one run mine out the taillight, into the trunk, and when i tow it gets hooked up, slack gets put back into trunk and door is shut, keeping it from dragging on the ground.
if you want to test it you can buy a sinple plug in tester from most places that sell hitches. if not, run by somewhere that has a trailer and plug it in.
if you have any more questions about it, pm me, i install converters, hitches, brake controllers everyday for my job. if you want ill grab the wire colour codes tomorrow from work.
31" kumhos 3inchs of lift.
Offline Ira88888
  • 23
« Reply #7 on: May 13, 2009, 03:07:26 AM »
Now I'm totally confused.
I thought I just plug a thing into that thing that's already there.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #8 on: May 13, 2009, 04:08:50 AM »
Nope.
The Suzuki/Tracker turn signal wiring requires a 5-wire to 4-wire converter in order to connect to the typical 4-wire trailer wiring system.
While there MAY be a kit that has a pre-wired adapter connector for the TracKick harness, most folks choose to splice in rather than spend lots of time searching for the adapter kit with the prewired plug.
Send mike5721947 a Personal Message (PM).  He sounds like an excellent resource for your project.
For information on the typical converter unit and what it does, do a search for trailer at Ack's FAQ (the link is in my signature).
Ack
Offline mike5721947
  • 545
« Reply #9 on: May 13, 2009, 09:48:23 PM »
there is no aftermarket plug in adapter for the stock wiring. it was a dealer only accessory and no aftermarket company made one since.
thats what i first looked for when i went to wire mine up.
its pretty easy to go out and get the converter, and a simple test light, strip the wires back and start probing the wires for which is which. most converter kits come with full instructions and some even come with a cheap test light.
trailer plug------truck
brown-----------running lights
green------------right turn signal/brake
yellow-----------left turn signal/brake
white------------ground
the green and yellow wires are what have to be converted the trackers and kicks use a 5 wire setup for the lights, they have seperate lights for the brake lights and turn signals, trailers have them combined.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #10 on: May 14, 2009, 04:59:47 AM »
This is what I used on my '96 2 dr.
http://www.hopkinstowingsolutions.com/products/basic_wiring/taillight_converters/standard_converters/tail_light_converter_60.html
You can find them at TSC, farm and fleet and some auto parts stores.
You can use the "fold over" wire taps to hook it up.  Best place to tap in is behind the driver's side tail light.  Taking off the inside plastic panel makes it easier.  You can get a test light that connects to ground and pokes a pinhole through the insulation to identify which wire is which.
I set mine up so just the converter box sticks out from the plastic side panel, and I use a removable 4 foot extension between the box connector and the trailer connector.
Good luck.  It takes about an hour.
« Last Edit: May 14, 2009, 05:02:14 AM by jzap »
Jim Z.
66 Apache camper
Offline mike5721947
  • 545
« Reply #11 on: May 15, 2009, 04:13:50 PM »
no need to wire tap it or jumper off any wires, as theres a plug in for a suzuki made wiring adapter (no longer made)
just remove the plug, strip the wires
running lights-red wire yellow stripe
left turn-green wire red stripe
right turn-green wire yellow stripe
brake lights-green wire white stripe
ground is body (theres the taillight grounding point just behind the taillight on the left. either jumper the ground wire or remove screw and use a ring terminal)
converter has all the wires labeled to what they go to.
trailer plug wiring
Offline keith
  • 1176
« Reply #12 on: March 12, 2010, 07:51:39 PM »
I used the post above for wire colors.  It was right and the lights worked right the first time.
« Reply #13 on: August 23, 2010, 10:36:24 PM »
Reving an old thread, I know, but....  I actually have the factory harness adapter for the tow package. My Tracker is a '90 model, and the adapter was buried in the drivers' quarter panel. My question is this: does any body know what the factory color codes are for the tralier plug, as the PO cut the freeking plug off!!! I have 2 wires unaccounted for. A heavy gauge Blue, and a heavy gauge White. The other wires are brown, NO trace,  Yellow, with BLACK trace,  and Green, with White trace.
 Thanks to any responders!
« Reply #14 on: August 23, 2010, 10:51:49 PM »
Not sure about the Track/Kicks, but on US truck wiring white is ground
and blue is power, the other wires would be some combination of stop
left and right turns, get out your volt meter, or go get a $5 cheep one
and give it a go, should be easy enough to figure out
