Fuel Press.
  • 1511 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Fuel Press.
« on: April 30, 2009, 10:30:09 AM »
I need to know what the press is for a 94 8 Valve with T.B.I. Or a part number that somebody has used before for an external mount fuel pump. My online mitchell manual says that I need 34 psi min. But sounds high for a TBI eng.
   Thanks,
     Kevin
Re: Fuel Press.
« Reply #1 on: April 30, 2009, 10:58:23 AM »
At the input to the fuel filter the pressure must be:
Static test:     34.2 to 39.8 PSI  (key on)
Residual test:   after 1 minute of key off , the pressure should be above 21.3 Psi .
At idle:           24.2 to 29.9 PSI.
The fuel pump should be rated at x PSI |removethispart|@ y Gallons Per Hour (or similar). Most pumps should be able to flow enough petrol to keep up the pressure on a Track/Kick engine.
« Last Edit: April 30, 2009, 11:01:32 AM by Rhinoman »
