Garvin Wilderness Roof Rack
  • 12 Replies
  • 5486 Views
« on: May 05, 2009, 10:26:48 PM »
For my J1 Tintop, has anyone used this rack before? if so, got any pics? as well as how many pounds it can take? im just a bit skeptical of bolting anything to the roof as the roof feels very thin! maybe the edges aren't as i haven't really checked. anyone has any thoughts about it?
J1 TINTOP FOR 500 BUCKS AINT BAD AT ALL!
Offline jawman
  • 406
  • 1234
Re: Garvin Wilderness Roof Rack
« Reply #1 on: May 05, 2009, 10:56:47 PM »
I have the same question. how much weight can the roof hold up?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #2 on: May 08, 2009, 12:38:18 PM »
I dunno bartolo but i've got a 1990 2dr hardtop, and trying to look into the same thing.  Either that or hack up a Calmini soft top rack to fit the HT.  Garvin's website lists trackracks...they bolt to a track setup...which I like, to spread the load out over a long rail, not just individual bolts :) i'll keep looking at this post for updates...
Garvin's TrackRack system lists a lot of different sizes, the SMALLEST is 40x52x4...and between the black plastic rail covers on my roof, i've only got 40" so it's a tight fit it looks like!
« Reply #3 on: May 08, 2009, 02:48:27 PM »
My roof rack uses the metal ribs below the rubber rain gutter (pull the gutter up and look). It looks wimpy, but it's NOT. When I made my roof rack, I was maybe 1/8" off, I tried hitting it with a 12 lb sledge to bend the roof "tab" over - it would NOT budge. I'm confident the weight limitation won't be what the rack can hold, but what will make my kick too darn top heavy.
Offline TopHeavy96
  • 488
« Reply #4 on: May 08, 2009, 04:17:10 PM »
Oops, sorry I thought I heard you call my name ;)
Jeremiah's right though, if you mount the rack to the rails, it'll get too top heavy(hey, there it is again ::))  before it folds under the weight.
Offline djlantis57
  • 871
« Reply #5 on: May 08, 2009, 04:27:25 PM »
hmmm very true.  I have yet to explore my Tracker...a busy full-time college student working 2 jobs.  I have driven it, and that's about it.  Haven't even taken the tires off yet.  Prob do that on my b-day next tuesday while I enjoy some time off
Offline lv2fsh
  • 312
  • 19
« Reply #6 on: May 10, 2009, 07:26:07 PM »
 :laugh: Guess you'll just have to sell it and buy a Sammy
Offline djlantis57
  • 871
« Reply #7 on: May 10, 2009, 07:31:34 PM »
ONLY if someone has one to trade in the same condition and the 1.6L EFI 'cause that engine is the main reason I bought a kicker!!!
Offline lv2fsh
  • 312
  • 19
« Reply #8 on: May 10, 2009, 09:44:19 PM »
Not trying to start a fight over which is better, just that rain gutters are good to have for holding up a rack too.
Offline djlantis57
  • 871
« Reply #9 on: May 10, 2009, 11:22:29 PM »
yea that's the great thing about a sammy hardtop, easy to do that.  has anyone modified a calmini soft-top rack to fit a 2dr hardtop?  they look similar enough, i was able to see a soft top model with a rack when I was at calmini in bakersfield last month.  looks like i'd have to reinforce my roof around the forward mounting points and maybe add a spacer to make up the difference in height.  but the rear mount looks the same on either side of my hatch no?
« Reply #10 on: May 14, 2009, 09:05:52 AM »
hi yal! thanks for all the post, iv been busy with school, but yeah, a hacked up calmini soft top rack, it looks like it will do but im not to sure, anyone done this before???? i mean i saw that yakima and thule can easily fit crossbars on my 2dr tintop but i really dont want something that looks overly modern, i like that rugged safari look!
Offline djlantis57
  • 871
« Reply #11 on: May 19, 2009, 02:57:58 PM »
Bartolo you got any pics of how you hacked up the soft top Calmini rack to fit?  I'm curious.  If it's simple enough, I might convert one to fit my hardtop
« Reply #12 on: May 24, 2009, 07:52:24 PM »
I have to give Chris at Garvin racks a plug, he helped me find an application for my 01 Tracker, drop them a message.  I removed the factory cross bars since I will not be carrying anything, they have a slick mounting system using the factory rails.  Once it is bolted down you can grab hold and tug all you want, the truck rocks back and forth, I can pull myself up on the rear and it nevers flexes a bit.  Keep in mind they have a tire mount for the roof, so it should hold quite a bit.  The instructions list a 200 pound limit, I have the 44" x 52" x 6" (38506) with multiple light mounts and the two side attachments.
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
