Lifting My 93 4 door Sidekick
  • 14 Replies
  • 5861 Views
Offline jawman
  • 406
  • 1234
« on: May 05, 2009, 10:54:35 PM »
My sidekick is a DD, but it is looking for some bigger tires and more clearance for an off road run every once in a while. My question is what is the best way to lift it and keep it easy and cheap at the same time?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline idaholwb
  • 772
Re: Lifting My 93 4 door Sidekick
« Reply #1 on: May 06, 2009, 12:06:27 AM »
Front and rear springs from about a 2004 XL-7... It gives you a great ride and around 2" of lift... Use the rear shocks as well, they are about 2" longer than the Sidekick rear shocks and bolt right on...
97 Sport
265/70-16s
2" lift
2.0 swap
Offline bzzr2
  • 1011
« Reply #2 on: May 06, 2009, 10:51:01 AM »
from what i know the xl7 REAR springs work (i run them but still use a 1.5inch spacer) for the FRONT you will want GV springs.
09 taco reg cab short box 4x4
Offline Pauld
« Reply #3 on: May 06, 2009, 06:36:09 PM »
Will this work on a '98 4 door Sidekick as well?
« Reply #4 on: May 07, 2009, 01:33:24 PM »
IHMO, 29" (or metric equivalent) is the tallest I think most people will be happy with on a 4-door. I have them on my 5-speed and I'm on the bleeding edge of having too little power (ESPECIALLY when loaded down with camping gear). But, I do live where there are twists, turns, and some hills. That said, some people are happy as pie with 31" tires. If you go with 29" tires, you may not need a lift at all, and can probably stick with your stock wheels.
If you do need a lift, it will probably be because your tires rub the frame at full turn. I recommend Jeff's spacer lift - it's by far the most bang of the buck lift for your 4-door. If you can afford to shell out $700 on a lift, the OME is hands-down the most comfortable lift money can buy. Calmini, and body lifts are options too, but I don't prefer either of them. I've ridden in a Calmini setup, and it's nowhere near as plush as my OME suspension.
Offline jawman
  • 406
  • 1234
« Reply #5 on: May 08, 2009, 10:10:04 PM »
I like the idea of a smoother ride. Will the XL-7 springs fit with no modifications? What are GV springs?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline norcalwreckchaser
  • 128
« Reply #6 on: May 09, 2009, 01:24:57 AM »
Grand Vitara
Sold 7/10 :(
Offline 4Zstracker
  • 250
« Reply #7 on: May 09, 2009, 09:25:39 AM »
I am running OME XL-7 springs in the front of my 2 door. OME springs are usually 1-1.5" taller than stock. I get just under 3 inches of lift with those springs. I went with them because the spring rate is closer to stock than GV springs are, so you get a smoother ride, and they are slightly taller. It rides and handles very well, I like it.
The one thing that will cause problems is that after installing taller springs or even a big spacer your truck is probably gonna look pretty pigeon toed due to the amount camber change. You can usually correct most of it with a set of camber bolts in the bottom hole.
if ya always do what ya always done, you always gonna get what ya always got...
Offline jawman
  • 406
  • 1234
« Reply #8 on: May 10, 2009, 08:23:54 PM »
does anyone have any pictures of your creations?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
  • 128
« Reply #9 on: May 10, 2009, 08:50:49 PM »
All kinds of "eye candy" here
http://www.zukiworld.com/forum/index.php?topic=35.0
Sold 7/10 :(
Offline MUD CHILD
  • 355
  • 9
« Reply #10 on: May 11, 2009, 11:41:07 PM »
I have a 2" suspension lift that I sell for sidekicks and trackers. It comes with 4 aluminum coil spacers, 2 strut spacers, rear diff third link spacer and all hardwear. You will need to buy longer rear shocks wnen you install the lift. I sell the kit for $275 U.S or $300 CND
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline trevorsride
  • 85
  • Coos Bay Oregon
« Reply #11 on: May 12, 2009, 10:37:14 AM »
Does your rear link spacer use longer bolts, or does it use two sets of bolts?
96 Geo Tracker 1.6 16V 3spd auto 2 dr soft top Jeffs 2" spacers, and 30" tires
Offline MUD CHILD
  • 355
  • 9
« Reply #12 on: May 12, 2009, 11:07:54 AM »
It uses two sets of bolts. You reuse your 4 original bolts to bolt it to the third member, and I supply 4 new bolts and nuts to bolt it to the third link.
« Last Edit: May 12, 2009, 11:09:35 AM by MUD CHILD »
Offline bzzr2
  • 1011
« Reply #13 on: May 13, 2009, 05:24:35 AM »
XL7 OME fronts eh... i had read somewhere they didn't fit properly or was too much lift...  interesting news!  to the question about the XL7 rear springs fitment, yes, no mods.  the reason i use them is that when i carry weight i don't want to lose ride height, i almost certainly lose ride quality but i get what i'm looking for..
Offline trevorsride
  • 85
  • Coos Bay Oregon
« Reply #14 on: May 13, 2009, 07:51:50 AM »
How much for just the 2" Diff spacer? And is it steel, or aluminum?
