2x4 to 4x4
  • 3039 Views
Offline Red Rooster
2x4 to 4x4
« on: May 07, 2009, 09:34:19 PM »
I ran upon a 2x4 zuki sidekick to for cheap, what would ti take to convert it to 4x4 and would it be worth it to convert???
Red Rooster
Looking to get
Zuking!
2008 Kawasaki Ninja 650R :-)
2008 Dodge Nitro (4x2) :-(
2004 Nissan Xterra (4x2) :-(
Offline Hillbillydave
  • 213
Re: 2x4 to 4x4
« Reply #1 on: May 08, 2009, 03:48:44 AM »
Welcome to the sickness!
You will need transmission, transfer case, front axle housing, front cv axles, and both driveshafts. You would basically need to find a donor 4x4. Sounds worse than it is, since it will be a bolt in swap, for the most part. REally depends on how good a deal you get on the 2wd. The 2wd's are built the same, just missing the 4wd pieces. Good luck and post pics of the conversion!
Offline TopHeavy96
  • 488
Re: 2x4 to 4x4
« Reply #2 on: May 08, 2009, 04:11:05 AM »
I also recommend a donor truck,  then  you can just swap the complete system from one to the other.  Also you probably already know this, but be sure too find out your current gear ratio so you get a front to match.  That's another good reason to have a donor car, so you can use the rear axle for the matching gears. It's definitely worth doin if you got the time.
Re: 2x4 to 4x4
« Reply #3 on: May 08, 2009, 04:44:06 AM »
I was told that you have to fabricate a front diff mount.
Offline locjaw
  • 2045
  • 22
Re: 2x4 to 4x4
« Reply #4 on: May 08, 2009, 07:08:04 AM »
i think you can buy the origonal mount from the dealer(drivers side frame mount)there was a topic here just the other day about this. Ill see if i can find it./
here it is.....
http://www.zukiworld.com/forum/index.php?topic=25142.0
Offline RHodge
  • 523
Re: 2x4 to 4x4
« Reply #5 on: May 08, 2009, 07:12:46 AM »
If you could I would do the SAS kit from trail tough
http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=167&category_id=18&option=com_virtuemart&Itemid=53
I don't know it would take much to put it in a 2wd but I'm sure it would save some time trying to get the IFS stuff under it
Offline locjaw
  • 2045
  • 22
Re: 2x4 to 4x4
« Reply #6 on: May 08, 2009, 12:14:57 PM »
a local guy put a slayer kit on a 2wd X-90. all he had to do was put a t-case in it.
Re: 2x4 to 4x4
« Reply #7 on: May 08, 2009, 02:36:33 PM »
What sized tires are you looking to go to? If you're going big, swap to toyota junk. If you're staying to stay stockish, you can just lock the rear and be just as well off as 4x4 and open diffs... cheaper & easier.
