Diff Spacers
  • 12 Replies
  • 4883 Views
Offline 4Zstracker
  • 250
Diff Spacers
« on: May 14, 2009, 08:59:01 PM »
Hey everybody
Jus wonderin; I have heard quite a bit about "diff spacers" on here and was wondering if anyone had some pix or suggestions on application, or info on how to get/ build one?
Thanks in advance fellas.
if ya always do what ya always done, you always gonna get what ya always got...
Offline TopHeavy96
  • 488
Re: Diff Spacers
« Reply #1 on: May 14, 2009, 09:32:44 PM »
Jeff1997 makes and sells a diff spacer,  it goes between the rear diff and balljoint.  I have it and I'm at about 3500 miles, checked the bolts and they're tight.(with locktight)  Seems like it makes the rear flex better by taking some tension out of the ball joint.
Offline MUD CHILD
  • 355
  • 9
Re: Diff Spacers
« Reply #2 on: May 14, 2009, 11:28:07 PM »
I make a two inch suspension lift kit for sidekick and Trackers. I include the rear spacer in my kit but I will sell the spacer seperatly as well.
Here are a couple pictures of the suspension lift kit that I make, You can see the rear diff spacer in the pic
« Last Edit: May 15, 2009, 09:24:14 AM by MUD CHILD »
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Re: Diff Spacers
« Reply #3 on: May 15, 2009, 12:20:29 PM »
Prices on kit & spacer separately?
Offline MUD CHILD
  • 355
  • 9
Re: Diff Spacers
« Reply #4 on: May 15, 2009, 12:35:05 PM »
I sell the kit for $275 U.S or $300 CND.  The rear diff spacer with hardwear I sell for $40
Offline 4Zstracker
  • 250
Re: Diff Spacers
« Reply #5 on: May 15, 2009, 06:54:23 PM »
What about your strut spacers, Would you sell them separately?
Offline MUD CHILD
  • 355
  • 9
Re: Diff Spacers
« Reply #6 on: May 17, 2009, 12:02:24 AM »
Sure I'd sell the strut spacers separatly aswell...$80
Re: Diff Spacers
« Reply #7 on: May 17, 2009, 06:09:24 AM »
 ;) Good looking stuff Mudchild. How's that Megasquirt workin' out?
Re: Diff Spacers
« Reply #8 on: May 17, 2009, 05:14:08 PM »
Hey everybody
I was reading of the failure rate of the top diff mount on raised and flexed rides, so I removed the ball joint and replaced it with a more flexible fix.
This is my solution
Side view
Testing place
I ground the mounts for better clearance and replaced the missing nut and washer.  Fit and flex great, and it is adjustable.
Offline 4Zstracker
  • 250
Re: Diff Spacers
« Reply #9 on: May 17, 2009, 10:05:30 PM »
how strong does this part of the linkage have to be to stand up to the stresses of articulation?
How long will the stock ball joint setup hold up?
Does the diff spacer restore the correct pinion/ driveline angles?
Offline chrisvitarasport94
  • 228
Re: Diff Spacers
« Reply #10 on: May 18, 2009, 08:44:12 AM »
diff spacer and 1/2" prop spacer made all the difference to my ride; ran it with 2.5" spacer lift before, and noticibly better after diff spacer added
Offline MUD CHILD
  • 355
  • 9
Re: Diff Spacers
« Reply #11 on: May 18, 2009, 04:13:36 PM »
Thanks
Unfortunatly the turbo project got put on hold for a little bit while I'm building a new truck.
Offline 4Zstracker
  • 250
Re: Diff Spacers
« Reply #12 on: May 18, 2009, 10:07:21 PM »
"Prop Spacer", Is that a driveline spacer? Better, but how so?
