More Lift on a 01 GV Tracker
chevytracker
126
May 24, 2009, 07:19:28 PM »
I just lifted my 01 Tracker with a Master Kit 2 inch body lift and coil spacers and need at least one more inch in the front. What can you suggest that is low dollar, I was going to get the Calmini lift for around $1200 since it has 4 springs and struts/shocks, locking hubs in about a year. I have spent too much and need to delay and big purchases.
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more. 95 Tracker with all Calmini bolt ons. 96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
sidekicksrock
416
Lil Suzys Dad
Re: More Lift on a 01 GV Tracker
May 25, 2009, 08:48:29 AM »
I am afraid that if you have a body lift and coil spacers (2" lift?) that is about it until you install longer A arms.
Why do you need extra lift in the front?
Student of Now Master of Then
jeff1997
1228
27
Suzuki: A Jeep thing only cheaper!!!!
May 25, 2009, 10:21:00 AM »
What size coil spacers do you have up front? If you have 1" or 1.5" you could go to a 2" col spacer. I sell 2" or any other size you may need. I also make the strut mount spacers if you need them. By the way, those rims look sick on your GV
2" coil spacers- I make and sell 1.5" and 2" on e-bay. Look under seller: hoepkers
3" Masterkit1 body lift
Custom strut spacers
bzzr2
1011
3
Reply #3 on:
May 26, 2009, 08:18:17 AM »
if all you have for suspension lift is the overpriced stuff from masterkit you could buy some OME springs, the masterkit spacers provide the same lift as the OME spacers that are usually used with the springs..
09 taco reg cab short box 4x4
