Sidekick third in sami axle
  • 1606 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« on: May 25, 2009, 01:50:31 PM »
Can someone refresh my memory . Will a sidekick front third fit into a samurai front axle or do you take the front ring and pinion out of a sidekick and in stall into a samurai third ???
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Re: Sidekick third in sami axle
« Reply #1 on: May 25, 2009, 02:57:01 PM »
Pre-96 will fit, after that you need to run the aftermarket front axles as the side gears change the spline count.  Front 3rd only.  :)
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #2 on: May 25, 2009, 03:10:06 PM »
So can I just put the side gears from a sammy into the sidekick carrier instead of upgrading the axles?
#801-554-3281
« Reply #3 on: May 25, 2009, 10:13:46 PM »
No, they have a different carrier. You will need to put the gears into the Sammy 3rd member.
