Steering knuckle seals
  • 2662 Views
Offline nh
  • 17
« on: May 28, 2009, 01:38:45 PM »
I'm changing out a front diff from a 90 sidekick and want to replace the steering knuckle seals. I took out one seal each side ,sort of a stepped housing seal. Every place I phone about seals ask" inner or outer" I only can find one and only a spot for one. Where is the second seal supposed to go?
Offline fuzzy1
  • 350
Re: Steering knuckle seals
« Reply #1 on: May 28, 2009, 02:14:53 PM »
Check this, exploded parts down the page a little:
http://www.kick-fix.com/hubs/hubs.html
Part 27 inner seal, part 19 outer iirc. May be good plan to replace both while you're there though. Be sure to properly torque the lock washer for the crush bearing using the proper tool. hth
Fuzz
Non Illegitimi Conterat
Offline nh
  • 17
« Reply #2 on: May 28, 2009, 03:30:34 PM »
Thanks for answering Fuzz, The drawing helps ..but    The seals #26 & 27 are the ones that  don't make sense. I've got one and can't figure where any other would go? maybe it will be clear when I get the other seal (it's on order).
I've taken the hubs off three trackicks and still haven't seen a crush sleeve bearing. The last two I replaced with the same bearing as came out, back to back outer races no crush sleeve.
nh
« Reply #3 on: May 29, 2009, 05:58:18 PM »
Fuzz
Nope.  26 and 27 are the inner and outer seals (they refer to whether they fit "inside" the wheel hub assembly or "outside" the wheel hub assembly).  The same seals are also shown in Figure 10 at the top of the page.....they are parts 4 and 5 (hub inner oil seal and hub outer oil seal).
Part 19 is just a washer.
Offline fuzzy1
  • 350
« Reply #4 on: May 31, 2009, 08:22:34 AM »
Fuzz
Ahh, I see... so they're a double seal sorta stacked on each other... ok makes sense, & thanks for correction.
Offline nh
  • 17
« Reply #5 on: May 31, 2009, 05:11:31 PM »
When the second seal came I figured out where it went. One goes in the back of the knuckle but the other goes onto the drive shaft. They were so tight on the shaft I was sure they were part of the shaft. They were probably the original ones. The metal part of the first fits into the rubber of the second like a labyrinth / slinger type seal.
nh
