8v into 16 v
  • 2319 Views
Offline Ddog87
  • 109
8v into 16 v
« on: June 07, 2005, 08:49:32 AM »
What does it take to put a complete 8v motor into a 16v rig. Wire harness computer ??? anything else
Offline 1bigtracker
  • 3409
Re: 8v into 16 v
« Reply #1 on: June 07, 2005, 10:35:30 AM »
WHY?
stu
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: 8v into 16 v
« Reply #2 on: June 07, 2005, 10:40:29 AM »
WHY?
stu
Maybe low rpm torque  ??? The 8v's were better in this as far as I know.
But on topic, I'd say you'd need the complete harness, computer and sensors from the 8v but then it would almost bolt in....
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Ddog87
  • 109
Re: 8v into 16 v
« Reply #3 on: June 07, 2005, 10:56:43 AM »
WHY?
stu
Blown motor can get 8v cheap
Offline 1bigtracker
  • 3409
Re: 8v into 16 v
« Reply #4 on: June 07, 2005, 11:56:34 AM »
the blocks are the same, you could keep it 16V with some work if you wanted.
stu
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: 8v into 16 v
« Reply #5 on: June 07, 2005, 01:14:37 PM »
stu
The block is the same, but I understand the pistons may not be "non-interference" enough in an 8-valve for a 16-valve head, so you would need to use the 16-valve pistons (and maybe the connecting rods -- again, which may be tougher than the 8-valve's).  The 8-valve crank may be different -- I understand that the 16-valve crank is better-balanced.
Are we starting to see a pattern here?
I'd either wait for a 16-valve truck to appear at a salvage auction (or in the classifieds/Thrifty Nickel) or stick the 8-valve engine/harness/ECM in your truck.
Grammer tip 'O the day:  ;D
8-valve's = Possessive
8-valves = plural
Ack
Re: 8v into 16 v
« Reply #6 on: June 07, 2005, 11:55:11 PM »
I seem to recall seeing a dyno test between 8V and 16V a good few years ago. 8V and 16V had the same power curve up to something like 3500 and then the 16V made more.
